I know I've done this once before but what's the best way to cut the std exhaust system so I can fit a can on it ?
Decent hacksaw & blades or a "Dremel" (sp) ? . |
i covered everything in the vicinity of the cut & used my dremmel.
I did my with a hacksaw and a car exhaust cutter, if I was doing it again I'd use an angle grinder, its quicker and you dont risk cutting your heel plates
#4 | |
![]() ![]() Real men do it with a hacksaw |
I used a hacksaw on mine
#6 | |
![]() ![]() ![]() I couldn't find what I was looking for (sounds like a song...). Ian, somewhere or other you did mention a specific type of hacksaw blade that you use... What is it ? . |
In your aldi store right now is an angle grinder for about 8 quid and they are selling blades too so if you need one now you know. I myself used the dremmel
piece of cardboard between your swingarm and your exhaust pipe then ANGLE GRINDER! 2mins job done (neat aswell). i try'd the hacksaw route but it wasnt evan marking the exhaust pipe.
#9 |
I had every intention of actually removing the exhaust before cutting it..... I'm sure that's what I did with my curvey....
#10 |
Steve,...No need to make the exercise more involved than neccesary. A new blade in a junior hacksaw will do the job fine. Ensure the teeth of the blade are angled away from you and so cuts on the forward stroke.
Use a smooth action and once the outer skin has been broken through it gets a whole lot easier. Using this method I managed a perfectly straight,neat cut in about 10 minutes tops. Good luck. ![]() |
Huge diesel spill | stuartyboy | SV Ecosse | 2 | 28-04-08 07:52 AM |
A huge thank you to everyone | metalmonkey | Idle Banter | 7 | 01-04-08 03:47 PM |
Crash.NET - Vermeulen: It's going to be huge. | NewsBot | News | 0 | 09-10-07 02:10 PM |
A HUGE box has arrived | Ed | Idle Banter | 19 | 28-09-06 02:57 PM |
Huge Relief | Sincs | Bikes - Talk & Issues | 20 | 29-10-04 05:43 PM |
