Old 28-02-06, 10:33 AM   #1
Cloggsy
Default Air Compressor for the garage... What spec?
I'm looking for a compressor for the garage... What spec do I need to operate an 'Air impact wrench' etc Looking for a decent one that doesn't cost the earth
Old 28-02-06, 10:42 AM   #2
Jelster
Gonna fix yourself now ?
Sorry....
Old 28-02-06, 10:53 AM   #3
Flamin_Squirrel
I bought a compressor from here:
http://www.diy-compressors.com/shop/starter-kits.htm
If you look at the Compressor choice link to see what compressor is suitable for which tool.
Old 28-02-06, 11:09 AM   #4
timwilky
timwilky's Avatar
There are a couple of things to look at. The power obviously and the size of the tank.
If you are going to be using a lot of air, ie spraying etc then you need a large tank as you are more intersted at the cfm you can deliver rather than the pressure which is of more use for air tools such as impact wrenches where you need high pressure for short durations.
Important then are you auxillary fittings. My compressor output goes into an evaporator to remove water and then branches, one to an adaptor and the other through an oiler and then onto 4 branch points in the garage with a pcl fittings. The idea is that my spay gun, spray airline pipe cannot become contaminated with lubricating oil. All my tools are pcl fitments and can only then fit onto the lubricated points.
Not Grumpy, opinionated.
Old 28-02-06, 11:16 AM   #5
Flamin_Squirrel
Tank size has nothing to do with cfm.
Old 28-02-06, 11:47 AM   #6
timwilky
timwilky's Avatar
Not quite in the context I was refering to,
The volume of stored air in the tank is indicative of the capacity of air capable of being delivered whilst the compressor is topping up. I agree there is more to the cfm than just the tank size. including pipework bore, and the pressure it is delivered at etc. However without that large reserve of air in the first place tasks such as spraying would see air delivery purely at the compressor pump rate and become "pulsy"
Old 28-02-06, 11:53 AM   #7
Flamin_Squirrel
Yep. Sorry, was being a little pedantic
Old 28-02-06, 12:41 PM   #8
For my respray, I've mainly used a wee joke compressor with a 6 litre reciever, from B&Q. On paper, totally inappropriate, but it worked just fine. But on the down side, it did blow up So I've just got an old stock SIP with a 12 litre receiver, still smaller than would be recommended for spraying but it works a charm.
I don't really know much abiout it, jsut some rules of thumb. How I judged it was, I check the consumption stat for the tools you're considering, and make sure the free cfm of the compressor is higher. The higher the better, and the bigger the receiver the better, in general- means the compressor will need to run less often,w hich generally means it'll last longer. Displacement in CFM and free CFM are different things though.
Also, consider noise levels... My old one was seriously loud, the new one's 89db IIRC)- which is still pretty loud. If you'll be uising it constantly, or at night, then really you want it to be as quiet as poss. But really quiet ones cost a fortune.
With tools, you might want an in-line oiler for it? Not sure about that, it's not something I've done. I don't really have enough use for them, I just use the paint gun and the air blower.
Old 28-02-06, 03:44 PM   #9
Blue Flame
Blue Flame's Avatar
Aldi's are selling one this Thursday with an air wrench etc as additional items.
See Here --->http://www.aldi.co.uk/special_buys/index.html
Is this any good ??
Triumph Sprint GT 1050 -Sexy Phantom Black; Powerbronze Screen
Previous >> K3 SV650S - Candy Copper;Lower Fairing Set;Fender Extender; Powerbronze Screen; HEL Braided Lines;
Blue Flame is offline   Reply With Quote
Old 28-02-06, 04:18 PM   #10
Well, Aldi do have a formiddable reputation as a supplier of heavy plant...
Who needs a compressor .. Blue_SV650S Idle Banter 15 26-04-08 08:35 AM
compressor husky03 Idle Banter 5 05-02-08 08:21 PM
Compressor for sale northwind SV Ecosse 1 25-09-07 08:22 AM
How big a compressor do I want? northwind SV Talk, Tuning & Tweaking 20 05-07-05 12:10 PM
12V compressor for tyres embee Ancillaries 1 14-02-05 10:24 PM
