Old 28-02-06, 07:16 PM   #1
Andy13_uk
Default Rear brake pedal problems...
Well, the rear brake is fine but when i press it, it doesnt return the the orginal position,
Put some WD40 on the bit around but hasnt helped, think it could be a spring??
Any ideas at all would be great, going to take it apart wkend and would like a few ideas first.
It not a problem as the brake doesnt stay applied BUT the break light stays on so bit of a hazard!!
Old 28-02-06, 07:24 PM   #2
svrash
Default Re: Rear brake pedal problems...
Try WD-40ing the switch
Old 28-02-06, 07:38 PM   #3
The pivot is sticky, try a squirt of WD40 or similar first, if the problem is eased then take the pedal off and make sure it's free on the pivot, if not chances are the lever is corroded, if so very carefully remove the fibre bush on the lever's inner circumference, under that you'll find the aluminium of the lever itself has corroded, clean it off and refit the bush.
Old 28-02-06, 07:45 PM   #4
Andy13_uk
Yea i think taking it apart and give it all a spray is the thing to do, i will do what you said, i have dont this with the gear lever recently (gave it a nioce clean while it was off) and improved alot. didnt get round to the brake so think i will ASAP
Least it the one easy bit of the SV to take on and off (though the gear lever is easier)
Old 28-02-06, 09:30 PM   #5
lemmings999
that is what has happened to my lever the other day
took it to the dealer and they did it for me
dont want to take parts of myself if i can help it at the moment
Old 28-02-06, 11:12 PM   #6
curium
http://forums.sv650.org/viewtopic.ph...181&highlight=
99-02 rear brake pedal Marcus Stuff Wanted 17 14-04-09 07:27 PM
rear brake pedal? seano Stuff Wanted 0 12-04-07 07:29 PM
Rear Brake Pedal 01 sv650s Stuff Wanted 1 29-03-07 10:11 PM
Rear Brake Pedal 01 sv650s Stuff Wanted 0 29-03-07 07:59 PM
Rear Brake Pedal teknovision2 Stuff Wanted 1 24-07-06 06:21 PM
