Old 04-03-06, 08:35 AM   #1
Grinch
Default Dangerous Bar Muffs
Can any one recommend a good technique for getting oxford bar muff on that mean I can still grab the front brake. Had a rather scary moment this morning, so I've removed them for now. I'll be having a look myself at lunch, but I thought I'd ask you lot in-case you had the same problem before. Ta.
Old 04-03-06, 09:27 AM   #2
jambo
jambo's Avatar
I always ride with 2 fiigers covering the brake lever anyway so they get abit colder than the rest of my hand but mean the bar muff can't get in the way. It's something I forced myself to do after a couple of hairy moments and now can't stop doing it even out on the open road
Other than that I've considered making some form of frame for the bar muffs out of coat hangers or similar gauge wire extendng from the bar end weight round the levers to give the bar muffs some structure but haven't had the time / need / inclination.
Old 04-03-06, 11:35 AM   #3
Grinch
I've never had a problem with them before on the GT, just must be the layout style of the SV that casued the problem.
Old 04-03-06, 11:41 AM   #4
jambo
jambo's Avatar
It does seem bike dependant, it's fine on the Kwak & a Thundercat, but they were a mennace on the bandit...
Sarj seems to have carved up a set quite severly for the tripple so the wing mirrors come up through the bar muff itself etc, so they don't move about much, maybe a similar slash and gafa tape / cable tie type affair would keep them where you want on the SV?
Old 04-03-06, 12:17 PM   #5
Iansv
I've got a set i've never fitted to the sv, never felt comfortable on the sv, used to use em alot on my gpz...
sorry no suggestions
Old 04-03-06, 12:46 PM   #6
Grinch
Well I'm sure I'll have plent of time to figure it out with a stanley knife and gafa tape. Though by then it will have probably warmed up and I wont need them.
Old 04-03-06, 01:07 PM   #7
21QUEST
21QUEST's Avatar
Have a look at this thread. Might be helpful.
http://forums.sv650.org/viewtopic.ph...hlight=#445859
Ben
Nemo me impune lacessit.
Old 04-03-06, 03:01 PM   #8
Stig
Originally Posted by Sid Squid
Ordinarily you just tighten the strap 'round the bars, inboard of the switchgear, although I normally make a hole in the muffs and put the mirror mount through them, (bolt in the mirror mount on a faired bike).
When they get a bit older thay can get a bit floppy, (fnarr), if this happens or if they flap about a bit, make a hole in the end and put the bar end screw with a washer on it through the hole so it's secured at both ends, this is a good idea if you find the muffs pull on the levers at higher speeds.
Muffs... Alpinestarhero Hardware 8 21-05-08 07:54 PM
Big Muffs on an SV? Kinvig Bikes - Talk & Issues 7 21-03-07 04:04 PM
Muffs Phantomtek SV Talk, Tuning & Tweaking 4 12-11-06 07:05 PM
Like my new muffs Grinch Bikes - Talk & Issues 9 30-11-05 07:02 PM
Is biking REALLY dangerous or only midly dangerous? thor Bikes - Talk & Issues 68 25-04-05 07:36 AM
