I have an 01 SVS, it seems when I open the bike up in first, the speedo gets up to about 20mph, the steering goes all light, then the speedo seems to show me slowing down, yet I am still accelerating
until an varying distance down the road, where the speedo 'picks up' quickly and seems to work ok again ...
This only seems to occur when I give it a fistful in first or go over a bump whilst giving it a fistful in second Any ideas??? ![]() |
It seems as though you 'co-efficient of friction' surfaces are on the blink
![]() This is remidied by slightly smoother/less harsh twisting motion of the right hand whilst in first or second gear - you will find your speedo works smoothly & correctly at all times then... Alternatively, have the speedo cable re-routed to work off the rear wheel ![]() ![]() ![]() |
I had the same problem.
![]() I solved it by hanging strings of onions on the front to add weight. This seemed to help. Goes rather well with my beret too. ![]() |
giving it a fistfull?
front wheel still on the ground when this happening? lol |
Isn't there a known problem with Curvy speedo sensors? I'm sure a few bods on here have had to replace them
#6 | |
Fished in
![]() ![]() ![]() I'm actully oddily busy at the mo so I'm only half reading posts ![]() ![]() |
Now don't tell me, but there's a puff of smoke and then the speedo starts working again, right?
#9 | |
#10 | ||
![]() The speedo seems to have become faulty more often now I have fitted a 14t front sprocket wonder if there is any relationship?!!? ![]() Seriously though, unless you do lots of touring/motorway, I can highly recommend a 14t front sprocket, it livens the bike up just that little bit. In a way its like giving the bike more HP ![]() |
faulty H-VIX system | hovis | Bikes - Talk & Issues | 17 | 07-07-08 05:50 PM |
Faulty indicator | flymo | SV Talk, Tuning & Tweaking | 10 | 22-04-08 09:06 PM |
faulty speedo ? | dangerous bri | SV Talk, Tuning & Tweaking | 4 | 21-03-05 03:10 AM |
