Old 13-03-06, 09:54 AM   #1
Grinch
Default Fitting a Scottoiler.
Anyone done a guide?
Or willing to give me a few pointers or even help out, could be tea and cake for you if you do...
Old 13-03-06, 09:56 AM   #2
TSM
The Sick Man
TSM's Avatar
What bike?
Old 13-03-06, 10:26 AM   #3
mysteryjimbo
Touring or standard?
Its dead easy. Even you can do it!
Old 13-03-06, 10:54 AM   #4
Grinch
Originally Posted by TSM
What bike?
SV650SX... lovely... scratched... dented... curvey...
Standard...
Old 14-03-06, 09:22 AM   #5
Grinch
So... who wants to help me then?
Old 14-03-06, 09:40 AM   #6
Cloggsy
I've got a guide for a K3+ bike, but not a curvy
I've got one for a KTM LC8 too
Old 14-03-06, 09:46 AM   #7
TSM
The Sick Man
TSM's Avatar
I put mine under the left side panel, next to the shock. Its hidden and you can easly check it without having to remove the rear seat, plus you dont loose any space.
On the frame there is a threaded hole, using the mounting kit you can mount the scottoiler there. The pipe to the sprocket can go behind the swingarm. The vac pipe goes between the fuel tank, splice into fuel valve vac pipe (note vac pipe not fuel pipe) and using the T peice place inline.
Well thats how i did it anyway and it still works fine when i last checked.
Old 14-03-06, 09:53 AM   #8
Grinch
I consider myself a bit of a clown when it comes to things like this, and I'm a tad worried about screwing up something that cost me 70 quid. Even someone bring there bike over as a guide would help... call me paranoid if you would but I'd rather be safe then sorry.
Also as I'm doing 140 miles a day I imagine I'll have to fill it up abit so I need to put it where I can get to it easily, or run a 'feed' pipe to.
Might invest in a lube tube...
Old 14-03-06, 09:59 AM   #9
Grinch
Just found this too...
SV Carb'ed guide
On the Scottoiler web site... !
Still a little paranoid...
Got any pics of the reservoir mounted?
Old 14-03-06, 10:09 AM   #10
TSM
The Sick Man
TSM's Avatar
Yes the colour is odd, it not that anymore.
Scottoiler Fitting K9 TheRamJam SV Talk, Tuning & Tweaking 14 09-06-09 05:11 PM
Fitting a Scottoiler FishyMug SV Talk, Tuning & Tweaking 4 06-02-08 05:12 PM
Fitting Scottoiler plowsie SV Talk, Tuning & Tweaking 32 12-06-07 06:42 PM
Fitting a scottoiler Gazza77 SV Talk, Tuning & Tweaking 6 25-04-06 03:52 PM
Fitting a Scottoiler Gazza77 Ancillaries 2 24-04-06 08:13 PM
