Right, I am officially annoyed. I was trying to fit my tail tidy and I got stuck at the removal of the front seat. I took the side panels off and you have two little allen bolts that attach the seat to the frame. But for love or money I cannot damn well move them, they are totally solid! Only trying with an allen key as I can't find a correct wrench head from Halfords. Plus the fact that the damn muppets that work there may as well be working in McDonalds. One guy said "What's a wrench?" Anyone know which tool I require as I think this is only possible with the wrench. I've mangled my fingers too. Grrrr!
It is possible with the Allen Key, you should be able to do most things with the tools in the tool bag, think it is just going to be a case of brut force mate,
Have you tried drenching the threads in wd40? Do it a couple of times over the course of 24 hours and it might help to loosen them. Don't use the cheapo tools though, or it might feck the alley key socket.
I know what you mean about brute force and belive me I've given it everything but still no joy. And not one to brag but I'm not exactly weak. I'll try the wd40 soaking method. Cheers chaps.
Dan |
Should be a 6mm hex bolt iirc.
#6 | |
Dan |
I don't know if it's the same allen bolt as the curvy but mine will take a sharp tap with a heavy hammer on the allen key to break the bolt loose.Make sure it's properly inserted first to avoid it slipping and shagging the hole.
That may need editing but you get what I mean ![]()
whats a wrench?
seriously i dont know. defo try the lubing it method with wd40 or similar penetrating oil first then try adding an extension onto the end of your allen key to make it longer so you can apply more force easier and they should come undone force x distance and all that. careful tho if its that stuck applying more and more leverage could round the allen head then you'd have to drill it out. |
#9 | |
#10 |
How stupid do I feel. I just used the allen key from the suzuki toolbag (and that little compartment is a pain in the **** too) and it was dead easy. I must have loosened them when I previously tried. Yet another daft thread by me!
Removing Front Indicators From a Pointy | COLZO | SV Talk, Tuning & Tweaking | 4 | 24-01-09 12:33 AM |
Removing Seat Unit 02 Curvy | Stewbie | SV Talk, Tuning & Tweaking | 4 | 31-08-08 10:31 PM |
removing front sprocket | pointy | SV Talk, Tuning & Tweaking | 3 | 31-05-08 05:44 PM |
Removing the mudguard - front wheel off? | Tiger 55 | SV Talk, Tuning & Tweaking | 14 | 29-08-07 10:54 AM |
k2 naked -panel you take of just before removing front seat. | ejohnh | SV Talk, Tuning & Tweaking | 1 | 02-12-06 09:32 AM |
