Old 16-03-06, 08:00 PM   #1
Default trouble getting neutral?
went out yesterday for a 40mile spin around the bridgenorth area and when i stopped at a local pub to warm my hands i couldnt get neutral, bugger me i try'd everything but to no avail. ended up turning the sv off with the clutch held in! after a hand warming session i started her up in first gear with the clutch in and just pulled away, from that point on everything was ok. so does a very hot engine effect the box or what? it hasnt happen'd before.
Old 16-03-06, 08:03 PM   #2
Cloggsy
Normally something simple like oil level too high/too low can cause this (or indeed, chain too tight/slack )
Old 16-03-06, 08:06 PM   #3
will check those things, i'm doing its 4k service sunday so prob a change of oil will help.
Old 16-03-06, 08:07 PM   #4
Cloggsy
Yup, that too
Old 16-03-06, 08:10 PM   #5
madmal
Yup, that too
try the deal at HG or K&N
Old 16-03-06, 08:32 PM   #6
Yup, that too
thats where i went for the stuff madmal, good value. better than the £130 my local dealer wants.
Old 16-03-06, 08:46 PM   #7
madmal
cripes, £130.00 tell them you dont want the gold watch included deal
Old 16-03-06, 09:29 PM   #8
lynw
mine was playing up recently. Could change up but not down unless I was accelerating... made filtering interesting to say the least.
Turns out there was salt and grime on the some part of the outside causing it. Think he said it was the cam/shim between the gear shifter rod and the gears themselves.
Im sure Rictus or Sid will be along to give the proper technical term for it, wasnt really paying attention as I was very late for work.
Neutral Light DarrenSV650S Bikes - Talk & Issues 3 09-05-09 05:12 PM
Cannot get my bike into neutral. ihitge Bikes - Talk & Issues 9 01-05-08 03:41 PM
Won't go into neutral veraliar SV Talk, Tuning & Tweaking 7 01-02-07 07:05 PM
Can't find Neutral Stu Soho Massive 7 12-10-06 09:05 AM
Neutral Wiltshire7 SV Talk, Tuning & Tweaking 21 17-01-05 04:41 AM
