Old 18-03-06, 08:25 PM   #1
Default oiling cables?
i havent got a cable oiler so whats the best way to get oil into them? it the only part of the 4k service i'm having trouble with.
Old 18-03-06, 09:36 PM   #2
no ideas?
Old 18-03-06, 09:54 PM   #3
Biker Biggles
Biker Biggles's Avatar
I just tip a bit of oil in at the top end and hope it runs down inside.That seems to work for the clutch,and the rest survive OK.
Old 19-03-06, 04:36 AM   #4
Paul C
Old school trick is to make a funnel out of a business card or other light cardboard, tape it to the high end with duct tape (seal the rolled edge as well). Then take the lower end off and hang it off the bike so the oil doesn't leak all over. Fill your cardboard cone with light oil, then work the cable in and out with your fingers until all of the oil has run through. Repeat if the oil dropping out is filthy. Don't know what you have available for oil over there, I use a product called Tri-Slide with teflon, has worked well for years on many bikes.
Old 19-03-06, 09:04 AM   #5
cheers!
Old 19-03-06, 10:40 AM   #6
andy owen
Hi, I use bluetac on the lever end of the cable (taking the cable off the lever first)shaped in to a small funnel, if you use oil mixed in with thinners it will travel through faster, the thinners will evaporate and leave the oil behind..
Old 19-03-06, 03:23 PM   #7
Clutch cables/Throttle cables Curvy 21QUEST For Sale - SV's and SV related items 0 05-08-08 08:45 AM
Chain Oiling G SV Talk, Tuning & Tweaking 24 14-05-07 01:09 PM
oiling bmc filter 01 sv650s SV Talk, Tuning & Tweaking 3 29-12-06 09:53 AM
Oiling / Lubricating the cables Thaleshwar SV Talk, Tuning & Tweaking 7 28-02-06 10:08 AM
Oiling my chain rpwoodman SV Talk, Tuning & Tweaking 28 27-01-06 02:28 AM
