Old 18-03-06, 09:36 PM   #1
chrisp
Default Front brake alternatives?
Hi, can anyone advise me on upgrading the front brakes on my 99 SVs, I was thinking about changing the calipers but don't know which ones fit.
Chris
Old 18-03-06, 10:09 PM   #2
Scoobs
Why do you want to upgrade? Bling or performance?
For a performance increase, bleed the system, clean the pistons and calipers, get some decent pads and some braided hoses.
Just servicing the calipers will reap rewards.
Old 18-03-06, 10:10 PM   #3
None, really. Apart from harrison Billets, which are stupidly expensive... You'd have to find mounting plates spaced to take different calipers- there's always rumours of these being available, but I've never seen any.
There's a guy on OldSchoolSuzuki who's making up blates to put Bandit 12 calipers on a Bandit 6, which I believe may have the exact same forks- but I don't know if these are available yet.
have you upgraded the forks? Upgrading the calipers with standard forks would probably not give you much of a benefit...
Old 18-03-06, 10:26 PM   #4
21QUEST
21QUEST's Avatar
You don't want more Brakes . Slows you down . You want to make full use of the SVs' sweet handling :P .
Ben
Nemo me impune lacessit.
Old 19-03-06, 10:57 AM   #5
chrisp
thanks, I'll knock that idea on the head then, I've serviced the calipers, new seals and HH pads, braided lines, they just don't feel like they're working, maybe it's just me being used to the ZXR brakes, I'll proberbly clean and blead them again, failing that I'll have to go on a diet.
Chris
Old 19-03-06, 07:31 PM   #6
steveg
steveg's Avatar
Default re
my last bike was a zxr750 & the brakes were a lot better than the sv's , however that had HH pads & braided hoses and a very sorted front end. However the zxr needed better brakes as it was alot quicker & heavier than the sv.
The brakes on the SV are ok ,I recon firming up the front forks would make a big difference
To be honest don't really need to use the brakes much on the SV due to its power / engine braking & sweet handling.
Cheers Steve
ex - red sv650s 06 reg
Now Triumph sprint 1050 ABS 05 Reg
AKA Papa Smurf
steveg is offline   Reply With Quote
Old 19-03-06, 07:47 PM   #7
Yup, I reckon the biggest upgrade for an SV's brakes is to reduce the front end dive- they're plenty powerful, but it can be difficult to put it on the road effectively.
Old 25-03-06, 05:12 PM   #8
butterboy
Default Re: Front brakes
Chris
I just recived a reply from a month old inqury about adapters sv to gsxr. I will forward any info I get,and ask them to post here. They are going to do a production run soon. I will keep you all informed.
Old 26-03-06, 12:25 AM   #9
HighSpeedAssault.com
Default Brake upgrade
Hello,
butterboy just emailed us the link to this site.
We are building a batch of our SV-to-GSXR brake caliper adapters right now, and will have them in two weeks, ready to ship. We will post here when they are done, with detailed photos.
Converts your SV to use 00-02 GSXR 750 (or 01-03 600) calipers. Race tested 2005 season.
We will also have our multi-adjustable rearsets. 1/2-2.5" adjustabilty. We will post pix of those as well.
All parts CNC machined. All parts race tested 2005 season.
Old 26-03-06, 01:30 AM   #10
TSM
The Sick Man
TSM's Avatar
Any idea on price?
Brake light switch sticking on with front brake rick0361 SV Talk, Tuning & Tweaking 6 11-06-09 06:20 PM
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) leegriffiths128 Stuff Wanted 0 23-07-08 09:11 PM
Rear Brake Alternatives Tris SV Talk, Tuning & Tweaking 5 11-03-07 11:48 PM
Front brake not activating brake light properly SVeeedy Gonzales SV Talk, Tuning & Tweaking 5 27-02-07 12:09 PM
brake light flickers when the front brake pulled in - K4 dclifford SV Talk, Tuning & Tweaking 9 05-09-05 10:39 AM
