Old 20-03-06, 01:16 PM   #1
silent
Default bolts with sheared off heads...
hello everybody, is there any way of removing bolts with a sheared off head...ie just the shaft of the bolt is in the threaded hole so there is nothing to grab and turn...
Thanks
andy
Old 20-03-06, 01:23 PM   #2
svrash
for allenheads i find a torx bit that fits in the hex tightly, tap it in a far a poss and use the attachments to undo it with a wrench
If its gradable, a pair of mole grips are good
screws i cut, drill and "easy out" it out
Old 20-03-06, 02:00 PM   #3
silent
its in the end of a clipon, the bar end isnt present and the bolt has snapped off about 1 mm below the lip of the end of the clipon.
I cant grab it,
there is no hex key bit left,
cut drill and "easy out" i dont know what it is could you explain please.
Thanks again
andy
Old 20-03-06, 02:20 PM   #4
Viney
I cant grab it,
Thanks again
andy
That happened to me. I brought a second hand clip on
Old 20-03-06, 02:26 PM   #5
skidmarx
You can drill it out, but centre punch the middle of the bolt first. Choose a drill slightly smaller than the bolt. This method is rubbish however as you will probably end up drill the thread within the hole.
You need an easy out thingy. Drill a smaller hole in the bolt, choose an easy out that will screw into the hole cutting a thread as it goes. As it is tapered, it will gradually tighten up as it goes into the hole. Now you might think this will only tighten the bolt further, but its got a left hand thread see, so you screw the easy out thingy in by turning clockwise. Go to a motor spares place and I'm sure they'll sell you a set and show you how to use them?
Old 20-03-06, 02:31 PM   #6
That's going to be a rotter... I'd replace the clipon too, much easier. Always nice when bolts shear off on replacable parts, instead of cylinder heads.
But, you could fix it by drilling it out completely, and either fitting a helicoil or tapping a bigger hole, drilling out the bar end and fitting a bigger bolt. You might get lucky if you drilled a smaller hole the size of the unthreaded width (ie, as wide as the bolt would be with the threads all removed). But that would be a best to do right, and you're drilling steel out of ally (so the surroundign material that you need to leave intact, is softer than the material
svrash was referring to the ever-popular bolt-extractor. Or bolt-****er as it's sometimes known. It's a reverse-threaded screw, you drill into the bolt, thread this in, it taps its own hole and in theory, draws the bolt out. In practice, they often snap off, and because they're incredibly hard they're a nightmare to drill out.
Old 20-03-06, 02:51 PM   #7
silent
hmmm
well its on a tl1000s clipon that i bought for the front end upgrade from a breaker...they didnt mention the above flaw in the clipons and i intend to raise hell...just wonder whether i should send them back or try extracting myself really now...
Andy
Old 20-03-06, 03:15 PM   #8
Send it right back, I would.
Old 20-03-06, 05:17 PM   #9
suzuki quality bolts show there ugly head again!
Old 20-03-06, 06:43 PM   #10
ianofbhills
If it was me i'd knock the remains of the broken bar end further into the bar and fit new bar end weights at the end leaving the broken part trapped inside the clip on for ever.
Its not like having half an extra bit of bar end weight in there is going to make a huge difference to your bike and it wont rattle around in there as its a snug fit.
It should knock in easy as the bolt keeping in tight in there has sheared so there is no clamping force on the weight anymore.
This way you wont have to mess about with grips levers switchgear etc and i wouldnt buy a new clip on just for that thats for sure.
Sheared radiator bolt. larigos SV Talk, Tuning & Tweaking 14 07-09-11 12:38 PM
Sheared Bolt - need help DarrenSV650S Bikes - Talk & Issues 33 28-12-06 10:03 PM
Smack heads and crack heads Razor Idle Banter 22 06-10-06 08:00 PM
Long bolts? Short bolts? andyaikido SV Talk, Tuning & Tweaking 6 25-01-06 04:53 PM
Sheared radiator bolt? Sponge SV Talk, Tuning & Tweaking 2 10-01-05 11:17 PM
