Old 21-03-06, 08:05 PM   #1
G - renamed
Default Serious coolant contamination in oil
You'd think I'd learn from past mistakes and get stuff sorted well before I need them.
Anyway, went to change the oil on my 2002+1999 SV-S that have been sitting for a couple of months now (was intending to do a trackday earlier).
I've had race bikes in my garage before over winter and never had a problem. It's attached to the house, so doesn't get too cold.
Anyway, oil seemed to be rather seriously 'mayonaisy' when I drained. Topping up coolant sees it coming straight out the oil drain.
We're not talking dribbling out, but flowing almost as fast as I pour it in.
Not good.
I have had a search around on here, but couldn't find anything relating to this situation.
Any ideas?
Is this is a common problem?
Any easy fixes .
G
Old 21-03-06, 08:11 PM   #2
chazzyb
Default Re: Serious coolant contamination in oil
In a nutshell, no. One bike I could maybe understand, but two????
Old 21-03-06, 08:19 PM   #3
G - renamed
When they were last used in December I had checked oil/water and it was fine.
Only thing I can think is that they are more susceptible to freezing than other bikes, so maybe both bikes had frozen water which managed to crack something.
Old 21-03-06, 09:35 PM   #4
If they had coolant in, then it usually contains antifreeze... There's quite a few gaskets that could cause that contamination, but for it to be such a major flow? No idea.
Old 21-03-06, 09:37 PM   #5
G - renamed
No anti-freeze, as they're race bikes .
Had race bikes in this garage for a few years and never had a problem before.
I've got a nasty feeling something serious has cracked somewhere.
Old 21-03-06, 09:46 PM   #6
nearest ive seen to that was a car with a crack'd cyl head
Old 21-03-06, 09:52 PM   #7
Blue_SV650S
G
I am afraid to say I think the term here is that it is f***d!!!
As you state it had no anti-freeze in it, it does sound like a cracked block. If you are really lucky it is just a head gasket, but … it’s more likely the block dude … new engine time
Old 21-03-06, 10:04 PM   #8
G - renamed
2 new engines .
I do have a road SV now, so I suspect that it may be losing an engine. That or gaining a load of tarty ohlins stuff .
Old 21-03-06, 10:45 PM   #9
You really need to see exactly what's gone. There's a fair few coolant flowing areas that are replacable, if the main casings are cracked then that's probably dead but if it's elsewhere- inner clutch cover mabe? Then it might not even be very expensive to fix.
PS if they're dead, but you find a crank in good nick, I might be tempted to take it off your hands I've got an engine in teh garage with a spun bottom end bearing, not really economicalyl worth fixing but it'd be something to do...
Old 21-03-06, 10:52 PM   #10
Robw#70
First thing to go is the core plugs in the heads, if your lucky they will have just popped out
petrol contamination riktherider SV Talk, Tuning & Tweaking 8 22-01-09 05:33 PM
Important contamination warning!!! Spanner Man Idle Banter 3 25-10-07 11:30 PM
Coolant help therealvw SV Talk, Tuning & Tweaking 3 07-08-07 08:02 PM
Sorry -coolant again tomjones2 SV Talk, Tuning & Tweaking 6 17-06-06 09:47 AM
Fuel contamination Ping Bikes - Talk & Issues 6 11-08-05 07:49 AM
