Old 22-03-06, 08:45 PM   #1
Vfr400
Default Hamicad and Space
Seeing as it was my Birthday earlier this week and getting some cash I'm thinking about buying a Hamicad, but prompted by another thread how much under seat space do you lose? As my SV650K5 has little spare room as standard (Datatool system 3 is fitted there) I don't really want to lose too much more if I can help it..
chris
Old 22-03-06, 08:47 PM   #2
mattSV
mattSV's Avatar
I didn't lose any space under my K3 SV1000 seat
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 22-03-06, 08:48 PM   #3
on the k3 its just the tool kit holder you loose mines rolling around under there
Old 22-03-06, 08:49 PM   #4
Carsick
You don't lose space, as such, you just lose the molded plastic bits that hold the fusebox and the tank prop.
I used a cable tie to hold the fusebox to the subframe and jammed the tank prop behind that.
Old 22-03-06, 08:52 PM   #5
Vfr400
Thanks, i was under the impression that there was no longer room to keep the tank prop in there.
chris
Old 22-03-06, 09:57 PM   #6
creamerybutter
chris
I think I lost the clip for the stand but the room was still there.
Old 23-03-06, 09:39 AM   #7
Foey
I didn't loose any space at all & i cut the bit off the old item with the fuse box holder & tank support holder & stuck it to the hamicad so everything went back exactly as it was before.
Space Man Daimo Idle Banter 15 30-01-09 11:21 PM
Traffic from Space lukemillar Idle Banter 3 14-08-08 09:44 AM
Space Putty Blue_SV650S Idle Banter 11 15-02-08 05:02 PM
Red Ones visible from space!! Red ones Idle Banter 8 04-12-06 07:19 PM
I need my space man... Moriarty Bikes - Talk & Issues 33 08-03-05 09:57 PM
