Old 23-03-06, 06:57 AM   #1
Full Throttle
Default Baffle Stuck
Hi, I managed to get the baffle out of one of my renegade cans but the other one is completely stuck, any ideas how to remove it? and is there anything I can do to make it easier to get it out next time?
Thanks
Old 23-03-06, 12:34 PM   #2
socommk23
mine used to get jammed
i used a set of pliers...grabed it and wiggled it furiously!
job done!
Old 23-03-06, 03:21 PM   #3
my scorp wouldnt come out the first time so i stuck the broom handle down from the other end and knocked it out.
Old 23-03-06, 04:05 PM   #4
mac
I dont know about the Renegade, but the baffles on my CCC can were held in with mastik ( after i had drilled out the rivet i still had to give the baffle a wiggle with some mole grips )
Old 23-03-06, 07:21 PM   #5
Full Throttle
Have tried with pliers but the damn thing still wont budge, guess I'll have to try the knocking it out from the other side method.
Cheerz
Old 23-03-06, 08:00 PM   #6
the mastik is to make it road legal, it seals the baffle in.
Old 23-03-06, 09:01 PM   #7
Full Throttle
When I remove it would applying copper ease or something be a good idea to help it come out easier next time?
Old 23-03-06, 09:06 PM   #8
pick all the dry mastic off the inside of the can, that will help.
mine did get easyer with time.
Old 23-03-06, 09:06 PM   #9
"better idea" leave it out!
Old 23-03-06, 10:24 PM   #10
Full Throttle
hehe
Scamera van stuck deejay77 Photos 11 14-04-09 05:50 PM
Stuck brake pad pin. Dangle_kt SV Talk, Tuning & Tweaking 15 25-02-09 01:34 PM
stuck in gear thinman SV Talk, Tuning & Tweaking 4 25-03-08 02:03 PM
Bolts on Reg/Rec stuck Colby SV Talk, Tuning & Tweaking 13 04-02-08 04:42 PM
something stuck? Stingo Idle Banter 2 30-05-06 04:32 PM
