Old 24-03-06, 01:53 PM   #1
Davies
Default Tonight.......
Hi guys,
Hoping to make it down tonight. Just wondering if anyone knows the front/back type pressures for a 99sv650 off hand?......going to do some maintanence on the bike before I set off. Not checked mine for a month
Paul
Old 24-03-06, 01:55 PM   #2
Viney
33f36r depending in tyres, but they are the stock pressures for the SV on stock rubber.
Old 24-03-06, 01:59 PM   #3
Davies
Cheers Viney, I'm running Metzeler M1 Sportecs....guessing the pressures will be the same.
Old 24-03-06, 10:23 PM   #4
lynw
Not necessarily. My Metzlers I was told were 36/36. My Bridgestone 020s Ive been told are 36/42. As Viney said, really depends on the tyre.
Still you would have found out by now if they were ok pressures for you :P
Old 24-03-06, 11:30 PM   #5
Stig
Tyre pressures are a personal thing. Recommended pressures for the SV (in general) are 33 front 36 rear as Viney states. However people tend to alter the pressures dependent on how they ride.
The pressures will also depend on how your suspension is set up. Those that prefer a more "comfortable ride" will probably want pressures close to standard or less. Those that are more of a "hard rider" will want more pressure to allow "exact feel of the road".
Personally I ride with "standard" pressures in my tyres, with "stiff" suspension settings. 15 weight oil and Hagon springs in the front and the rear has a gixxer 750 shock fitted all wound up to max.
I have tried different pressures, but have found that "standard" feels best. Anything more than a couple of PSI either way just doesn't "feel" right.
Like I said, it's a personal thing. Something that can be experimented with until you find what suits you best.
BIG D's Tonight newts924 Pennine Massive 1 18-09-08 10:34 PM
ITV tonight 9.30 Quiff Wichard Idle Banter 13 24-08-08 10:21 PM
What to do tonight ... need some help Shellywoozle Idle Banter 83 12-03-08 09:36 AM
Didn't go out tonight... Stingo Idle Banter 34 15-11-06 09:35 AM
mfn tonight 22 The Madlanders 0 25-04-05 04:05 PM
