Old 02-04-06, 10:22 PM   #1
antony
Default brake discs
i seem to have a problem with my font discs you can grab hold oh them and wobble them front to back i guess this is wrong its only an 03 reg bike and i thought that they would last longer than seven thousand miles any one else had this problem
cheers
Old 03-04-06, 12:10 AM   #2
Depends exactly what you mean... The discs are semi-floating, which means they're not mounted solidly to the wheels, there's a little play in them.
Old 05-04-06, 06:29 PM   #3
antony
yeah realise that they move a little i think mine move about 2mm but my mates tl1000 ones dont move at all it was the scruitineer that picked up on at racemeeting and didnt really want to let me out it did not affect braking performance though
Old 05-04-06, 07:17 PM   #4
creamerybutter
There is only a tiny amount of play on mine it's next to nothing.
Old 05-04-06, 07:34 PM   #5
Shouldn't be that much, I think. The bobbin/rivet things can come loose, from memory, though I've never come across that.
Old 05-04-06, 10:11 PM   #6
antony
seems another bloke has got same problem at my mates work checked mine again and its only about 1mm of play if that but they will fail it next time i thought of knocking rivet things with a punch to take up play as new discs are 260 quid does anyone know if they can be fixed or where to get cheap ones ta
Old 06-04-06, 11:55 AM   #7
jambo
jambo's Avatar
Right I'm assuming that there is no play from the carrier itself where the disc is bolted to the wheel, and it's all between the carrier and the braking part of the disc itself. I've never had more than a very little movement there, are both discs the same? How many miles has the bike done, and do the actual discs look worn at all?
Edit: Look online or in MCN etc and there are companys that will fit new braking parts to old rotors so would be able to help I guess.
Old 06-04-06, 04:09 PM   #8
haggis
Yeah, mine do that too. R/h more so than left.
Do you get a dull clunk noise if you rock the bike fwd and back with the front brake on?
I'm sure replacement bobbins are available, never bother ed to track them down myself. If you find someone give me a shout!
I'm not a heavy braker, discs are barely worn at 22K on original pads.
Old 06-04-06, 09:24 PM   #9
antony
yeah carier is fixed ok its the forward and backward movement on the round things thats the problem bike has done 7500 steady miles it was restricted from new to 33 bhp there is no wear on discs and they dont wobble side to side
Old 07-04-06, 11:30 PM   #10
Stig
They are called float buttons. They are designed to move laterally. ie side to side. This is to prevent vibration when braking. They are hardly supposed to move forward or backwards at all. Lateral movement is quite normal and to be expected. Forward and backward movement however is not to be expected. At least not to the degree that you have mentioned.
Brake Discs iffy SV Talk, Tuning & Tweaking 7 05-03-09 11:18 AM
Brake Discs Warthog For Sale - SV's and SV related items 5 09-09-07 09:21 PM
EBC Pro-Lite brake discs and Goodridge GH brake pads r4ce_e3nd For Sale - SV's and SV related items 7 14-04-07 07:37 PM
Brake Discs for GSXR front end conversion on SV 320mm discs Ter For Sale - SV's and SV related items 0 22-09-06 04:50 PM
Brake Discs cosmiccharlie SV Talk, Tuning & Tweaking 2 13-02-05 11:15 AM
