Old 08-04-06, 08:00 AM   #1
timwilky
timwilky's Avatar
Default Fitting Honda RR
Guys
once again your advice is required
Having decided my charging problem is down to my RR I have followed advice and got my hands on a Honda RR from a CBR6RR
The model number is SH678FA
OK this RR has 3 yellow wires so I guess they go to the altenator, it is the other 4 wires my question relates to, there are two red and two green. So where do these go.
The couple of wiring diagrams (Not CBR6RR) I have looked at would suggest that these wires are coupled beyond the connector block together to make one red + and one green -
If anyone has a wiring diagram for a 2005 CBR6RR can they post the part that relates to the charging circuits
Not Grumpy, opinionated.
Old 09-04-06, 08:09 AM   #2
falc
Hmm I did this a while back on my sv, not sure on how many wires it had but when I get home ill have a quick flick through my haynes and see if it stirs any memories
Old 09-04-06, 10:35 AM   #3
timwilky
timwilky's Avatar
Well I ended up metering out the two reds and two greens, as far as I could tell they was nothing between them so I ended up soldering them together and into existing connections.
Metered out the battery and I am now seeing 13.8v at 5000rpm with lights on. So I guess this £20 RR has done the trick.
What did initially concern me was after I had disconnected the old RR and was moving the wires there was an electrical "flash". When I then removed the RR I noticed the alarm cables that had been routed behind the RR mounting had chaffed. Well that explains why my alarm fuse had blown last week whilst I measured the alternator output voltage, but why a 15 Amp fuse for an alarm, I replaced that with a 10 Amp, but that is probably still over rated..
This is the second time I have caught loom damage. Is this a Suzuki phenomenon or do all bikes suffer it?.
Old 09-04-06, 11:31 AM   #4
Peter Henry
Tim...It's a Suzuki mate! I thought you would have known that such things are synonymous with the brand? Rather than the scurrilous rumours that suggest such things are more prevalent on Italian machines! :P
Honda’s C-ABS Lucas Bikes - Talk & Issues 33 12-04-09 09:04 AM
Honda C90 rob13 Bikes - Talk & Issues 33 08-01-09 08:50 PM
If you wanted a Honda buy a Honda... Not a Honda SV sv_rider1990 Bikes - Talk & Issues 26 16-06-08 02:33 PM
Honda VTR Dave The Rave Bikes - Talk & Issues 7 23-05-08 07:30 PM
BAR Honda versus HM Plant Honda curium Bikes - Talk & Issues 2 10-11-05 10:51 AM
