Old 10-04-06, 02:04 PM   #1
svrash
Default Suspension bearings???
Got some play from the lever cushion (pic below) and I need to replace the bearings and spacers (all the bits maked green)
Going OEM will cost me £77.74 from the local dealers
I've got the bearing measurements from the fiche so can i get the bearings from else where and if so where?
Old 10-04-06, 02:35 PM   #2
When you find out, go and tell me? Mine aren't too happy.
Old 10-04-06, 05:43 PM   #3
Check the bearing on the underside of the swingarm while you're doing that lot.
IIRC it's the same as the ones in the centre of the linkage.
Old 10-04-06, 06:19 PM   #4
21QUEST
21QUEST's Avatar
Add me to the list
Ben
Nemo me impune lacessit.
Old 10-04-06, 06:21 PM   #5
TSM
The Sick Man
TSM's Avatar
Have a looki here: http://www.thebearingshop.com/F1.htm
Old 10-04-06, 08:57 PM   #6
svrash
Looks like no one i can find does the bearings in the size needed for the linkage (1x 20x27x30, 2x 20x27x23.5, 1x 12x20x32), i think OEM is the only way to goes or get them made by someone for more then OEM prices
Old 23-04-06, 02:05 PM   #7
FinSV650s
Default Needle bearings in the swing
I have just changed my rear shock absorber (Öhlins) and I did take a look at the bearing in the sving and the rear cushion lever (part 3, Chassis 6-37)
Under the sving arm KOYO BKM 2024JAU 2pcs
Dogbone side KOYO BKM 2024JAU 2 pcs
Frame fixing point KYO BHKM 1726 JUU
Raer Shock absorber fixing KOYO BKM 2030 JUU
It is just to take this number to a company who sales bearings and they should be able to help, it dosen't have to be KOYO since all the bearing manufacturers uses the same number for a certen bearing.
Let me find a picture of the parts and I will write in the bearing numbers.
PS. Don't have the number for the sving main bearings.
I will check with at my work what the price is.
/Mats
Old 23-04-06, 03:33 PM   #8
Spanner Man
Afternoon folks.
Be carefull when ordering bearings by their number, as a fairly recent trick that the Raw fish eaters have come up with, is to fit a bearing with a standard number on it, that isn't a standard bearing! i.e. An R6 rear sprocket carrier bearing is marked 6206, only the centre hole is a different size to a standard 6206, so instead of being 8 or 9 quid the bleeder is around £24!!
Only this week a chap came in to me with the rear suspension arm from one of those Honda silver wings with a knackered bearing in it. It was marked 6204 but had a 2mm larger bore.
Bearing (bad pun) in mind that you'll need to replace the spacers along with the linkage bearings and these are o/e only it's often not woth faffing around to save a couple of quid.
Cheers.
Spanner Man
Old 23-04-06, 03:36 PM   #9
Razor
My Sv has only done 11,000 miles and feels tight. At what milage are the rest of you replacing?
Old 23-04-06, 05:12 PM   #10
svrash
69,000
Bike Bearings TSM Bikes - Talk & Issues 14 23-05-09 07:01 PM
bearings sv_rory SV Talk, Tuning & Tweaking 5 12-02-09 07:29 PM
front bearings? noob-saibot SV Talk, Tuning & Tweaking 5 15-09-08 05:42 PM
swinging arm suspension linkage bearings 21QUEST SV Talk, Tuning & Tweaking 13 05-08-08 01:40 PM
Problem with the new bearings DarrenSV650S SV Talk, Tuning & Tweaking 9 17-05-08 10:52 PM
