Old 14-04-06, 05:00 PM   #1
silent
Default forks springs: HELP URGENTLY PLEASE!
i need help urgently,
i have tried to fit progressive fork springs for hyperpro, but they are longer than standard and i cant get enough weight on them to put the fork caps on...what do i do? am i doing something wrong...help please as the bikwes sat on the drive!
thanks
Andy
Old 14-04-06, 05:26 PM   #2
BILLY
Have you tried jacking the bike up from under the engine so it extends the forks more, does it say anything in the instructions about cutting you spacers down?
Old 14-04-06, 05:28 PM   #3
silent
the bike is jacked up, but i havent seen anything about cutting the spacers, illl have another look though.
ANy other thoughts, apart from put loadsa pressure on it ?
thanks
Andy
Old 14-04-06, 05:41 PM   #4
BILLY
When I did my springs with the bike jacked up the top of the spring was just below the stanchion and I had a 1in spacer, I just put the cap ontop of the spacer and pushed down but be careful not to cross thread the cap!!!!
Old 14-04-06, 06:24 PM   #5
21QUEST
21QUEST's Avatar
thanks
Andy
No other thoughts but it should not be that hard to put the top back in. Even if you do manage to put the cap back on you would more tahn like like have too much initial preload.
How much of the spring have you got sticking out of the stanchion? Have you go adjustable caps?
Ben
Nemo me impune lacessit.
Old 14-04-06, 06:29 PM   #6
silent
no adjustable caps, and there is about 6cm maybe more of the spacer sticking out of the forks.
i was thinking the preload would be too much...but i know nothing...
anyone think there should have been a spacer with the kit? and it wasnt included?
Andy
p.s. my bike now wont start after faffing about with the back putting a zxr shock on, the main fuse blew, so i put the other one in, and it still wont start, so i try to ake it out and blow that one...
when i say wont start, nothing comes on at all....any thoughts here
thanks!
Old 14-04-06, 07:05 PM   #7
BILLY
Some spring kits come with spacers some require you to use the origonals cut down! Did you disturb any wiring when you installed the shock it might be shorting out some where!!!!
Old 14-04-06, 07:38 PM   #8
21QUEST
21QUEST's Avatar
6cm(60mm) is definitly to much. No need to even think about spacers at this point.
A few maybe silly questions for you . With the way it is we will be looking at cutting the springs themselves down
You sure you have the right kit?
How have you raised the front?
Ben
Old 14-04-06, 08:08 PM   #9
socommk23
you will have been given replacement spacers! or you will have to cut down the origonal ones! the origonal spacers and aftermarket springs do not go together!!!!!!!
spacers will have to be round 25mm long! then put spring in then put top cap on!
does help if you hang bike from the garage roof or something else.....dont have the bikes weight on the froks!!
hope this helps!
Old 14-04-06, 08:22 PM   #10
Robw#70
Hyperpro dont come with spacers they are all meant to be drop in kits, You have the wrong springs
USD GSXR1000 k1 forks | standed forks - curvy Nicky S SV Talk, Tuning & Tweaking 113 07-09-09 01:12 PM
urgently needed!!!! sv650nutter149 Thames Valley 8 31-07-08 10:35 PM
Needed urgently Lozzo Bikes - Talk & Issues 2 26-03-08 02:04 PM
Urgently needed 01 sv650s Stuff Wanted 1 05-05-07 03:16 PM
help or advice URGENTLY NEEDED PLEASE dksv650 SV Talk, Tuning & Tweaking 24 27-11-06 01:05 PM
