Old 15-04-06, 10:41 AM   #1
VR46
Default I NEED YOUR HELP.......URGENT
Im need to change the battery asap.
I have removed seat and found the battery, how do I actually remove it?????
Any help is much appreciated.
Its a naked curvey '02.
Rob
Old 15-04-06, 10:44 AM   #2
socommk23
unscrew the two conections on positive and negative!
pull out!
Old 15-04-06, 10:48 AM   #3
VR46
I had a quick look look, will is pass the document tray ok then? Its all looks a bit tight so I was not too sure if other things have to be removed....
rob
Old 15-04-06, 11:04 AM   #4
21QUEST
21QUEST's Avatar
Unclip the The Box(with the fuses) sitting on top of the battery. The cable tie(underneath the box is also a push fit pin. Pulls out to give you more room.
Negative/black first making sure it kept well away from a metal part of bike Then the Positive/Red next
On reconnection Positive first Then Negative.
Ben
Nemo me impune lacessit.
Old 15-04-06, 12:34 PM   #5
VR46
Thanks Guys.
I know that my questions may seem silly but I really am useless when it comes to using a spanner
Once again your help is much appreciated.
Rob
Old 15-04-06, 12:46 PM   #6
socommk23
hope it went ok!
tis an easy job.
URGENT, please help ash SV Talk, Tuning & Tweaking 7 11-01-08 07:06 PM
Urgent!!!! BigB SELKENT 0 06-06-07 04:39 PM
Urgent Ward8124 Stuff Wanted 4 23-02-06 05:41 PM
Urgent HELP!!!! Samurai SV Talk, Tuning & Tweaking 12 22-02-06 10:35 PM
URGENT! suzsv650 SV Talk, Tuning & Tweaking 2 26-05-05 04:35 PM
