Old 15-04-06, 08:18 PM   #1
mart
Default how do you calculate rake and trail
as the tittle says is it possible to work out rake & trail and how would you do this for a given bike
Old 16-04-06, 12:51 PM   #2
Easiest to use makers quoted figures, failing that get the bike on a perfectly level surface, using a spirit level and a protractor measure the rake, unless you've got a Harley forks and steering axis will be parallel, if they're not it's complicated. Trail - measure from point directly below front spindle to extended steering axis point - keeping sttering perfectly square. For ease I'd probably make some measurements and produce a diagram.
Old 16-04-06, 03:54 PM   #3
mart
thanks squid
Old 16-04-06, 07:22 PM   #4
21QUEST
21QUEST's Avatar
Are you trying to work out how different changes affect the rake and trail?
Ben
Nemo me impune lacessit.
Old 16-04-06, 11:03 PM   #5
extreme3d
This site explains what to measure:
http://www.sportrider.com/tech/146_0310_art/
Old 17-04-06, 10:13 PM   #6
mart
thats a handy site. no just want to see the difference between the gsxr forks conversion and the stock sv forks and to try and counter act any problems that may arise with it i know a steering damper helps but im not too pleased to have a 120/50 front tyre on
Old 17-04-06, 10:36 PM   #7
21QUEST
21QUEST's Avatar
Originally Posted by mart
.......but im not too pleased to have a 120/50 front tyre on
You mean a 120/70 ?
Nice link extreme3d. Helped confirm a few bits for me.
Inch difference in fork length is equivalent about 1 degree reduction in rake. Personally I work with 0.03714 dgrees for every mm.
My calculations are these
Depending on how much shorter you make the GSXR forks(some say 20 mm but I make it about 25mm) , these are my figures
Forks 20mm Shorter
120/60/17( Dunlop 220) with rolling radius 288mm measured TRAIL=93.53
120/70/17(Pilot Road) with Rolling radius 299mm measured TRAIL=98.44
Forks 25mm Shorter
120/60/17(Tyre as above) TRAIL= 92.46
120/70/17(Tyre as above) TRAIL=97.33
Those figure are for the curvy with standard rake taken as 24.8 degrees/GSXR forks flush with top yoke. Yoke offset for the GSXR600/750/1000 up to K3 is 32mm.
The yoke offset for the SV650 Curvy is 29mm by the way. Don't know the offset for the Pointy.
Ben
Old 22-04-06, 03:10 PM   #8
xj/frosty
Im racing a curvy with gixxer front end and some JHS internals
its effectively steepened the rake about 1 degree.
a lil advise dude --if youre thinking of doing it get the forks rebuilt using .95 springs --the difference is un believable
Old 22-04-06, 03:19 PM   #9
21QUEST
21QUEST's Avatar
xj/frosty , if you don't mind me asking how much do you weigh (With gear or without).
Also did you have the forks lengthened? Personally don't think really required with a 120/70 but just curious.
Ben
Old 22-04-06, 03:41 PM   #10
xj/frosty
I' 176cm and currently weigh in at 68 kg nekkid--scales are right by the shower
And nope diddnt have the forks changed externally--Ive actually got em pushed through the yokes 12mm (1/2 inch) to quicken up the steering.
Mind you -My setup isnt soposed to work -Im running an ohlins shock setup for a k3 gixxer 600 with 97mm doggies. Looks like is bums hanging down compared to other sv's. I've always used a lot of body english so it seems to suit my riding style .
Trail braking. Blue_SV650S Bikes - Talk & Issues 33 16-10-08 12:30 PM
Hull Freedom Trail andywilson460 Idle Banter 0 01-07-08 09:04 PM
The new hotness (my trail bike) the white rabbit Photos 17 02-02-08 08:18 AM
rake angle alteration Little Rich SV Talk, Tuning & Tweaking 42 20-10-06 02:27 PM
Trail riding RWR Bikes - Talk & Issues 16 17-01-06 10:24 PM
