Old 25-04-06, 11:55 AM   #1
steveg
steveg's Avatar
Default how to adjust clutch free play
My sv650s k5 needs the clutch cable adjusting as there is too much slack as the cable has stretched .
How do I adjust the slack ?
Cheers Steve
ex - red sv650s 06 reg
Now Triumph sprint 1050 ABS 05 Reg
AKA Papa Smurf
steveg is offline   Reply With Quote
Old 25-04-06, 12:00 PM   #2
JakeRS
Need to find this out too... my lever had a lot of freeplay, so I adjusted the screws next to it... and it was fine for a day and now the freeplay is back...
Old 25-04-06, 12:05 PM   #3
Viney
i Doubt if the cable has stretched that much. The clutch needs adjusting.
Wind the adjuster fully in
Take off the front sprocket cover
using a 10mm amd 12mm spanner, adjust the cable. The lever should be at a little above horizontal (in front of the sprocket)
Tighten up the lock nuts.
you will see a small crewdriver slot on the thing that the lever is attached to, and around this is a 10mm nut. loosen the nut, and turn the screw clockwise until you feel some pressure, then turn back a little. Holding the screw so it dont move, re tighten the nut.
Once done, you can adjust the freeplay at the lever end to suit.
I hope this helps
Old 25-04-06, 01:05 PM   #4
Red ones
Red ones's Avatar
you will see a small crewdriver slot on the thing that the lever is attached to, and around this is a 10mm nut. loosen the nut, and turn the screw clockwise until you feel some pressure, then turn back a a quarter turn. Holding the screw so it dont move, re tighten the nut.
I hope this helps
If you turn it back a quarter turn you will find it is almost spot on. Make sure the lock nut on the handlebar end is locked - it sounds like it worked loose after you adjusted it!
Old 25-04-06, 01:34 PM   #5
branny
this is just what i need....
ive been tying myself in knotts trying to adjust my clutch properly!
it seems i either get a load of lever freeplay, or a clutch that wont disengage fully....
im gonna give this method a go tonight!
Old 25-04-06, 04:02 PM   #6
kciN
Ditto..
Always wondered, I'll be adjusting this weekend...
Old 25-04-06, 09:43 PM   #7
http://forums.sv650.org/viewtopic.ph...=clutch#451408
Old 25-04-06, 10:29 PM   #8
steveg
steveg's Avatar
Default re
adjusted clutch cable :-
Loosened the lock nut ( it had already worked loose from new) at lever & took up slack , strange thing was i took up too much slack initialy , therefore backed off adjuster at lever & this did not increase slack , which was strange , therfore took off sprocket cover & slightly backed off adjustment at lower cable adjuster which did the trick , just fine tuned to 15 mm via lever adjuster.
did not touch the clutch screw as only done 2k miles .
Also dropped the clutch & brake level slightly as appears too high as standard ( might be me)
Cheers Steve
AKA Papa Smurf
Adjusting clutch play lawriejones1 SV Talk, Tuning & Tweaking 8 01-12-08 09:10 PM
Is there a way to adjust the clutch lever? shonadoll SV Talk, Tuning & Tweaking 10 12-04-08 07:54 PM
Fantasy BSB competiton - Free to play Colby BSB & WSB 0 20-03-07 10:55 AM
Throttle free-play Jabba Bikes - Talk & Issues 18 29-08-06 01:15 PM
clutch lever play branny SV Talk, Tuning & Tweaking 4 09-07-05 12:12 PM
