Old 26-04-06, 03:23 PM   #1
doe
Default Ignition coil and CDI unit
Where can i buy an ignition coil. None of the breakers round me have one for a 99 suzuki. And how do i take out the CDI unit? I can see it at the rear of the pillion seat, but i can neither take out the cable nor reach with a screw driver.
Thanks
Old 26-04-06, 06:23 PM   #2
doe
I think i may have source the ignition coil. Can anyone advice how i can get at the CDI or remove the cable connecting to the CDI unit.
Thanks
Old 26-04-06, 07:14 PM   #3
TSM
The Sick Man
TSM's Avatar
The CDI should be under the rear seat, a multi pin connector into a box about 6x6cm screwed into the undertray.
The ignition coil just has a wire connected to it that is needed for the timing of the sparks.
Old 26-04-06, 07:41 PM   #4
doe
Thanks TSM. i have located the CDI unit, but i can't get out the pin connector. I am getting ahead of myself, but i trying to know were everything is b4 the weekend when i take the bike apart.
Old 26-04-06, 08:14 PM   #5
TSM
The Sick Man
TSM's Avatar
Any reason you are taking the CDI off?
I found that the connector was tough to remove first time. I pushed the lock down then used a screwdriver to gently edge the connector out.
Old 26-04-06, 08:57 PM   #6
doe
Thanks Again.
http://forums.sv650.org/viewtopic.ph...662&highlight=
The bike packed up on the M25. Rectifier burnt out. I changed the rectifier, New battery, but bike won't start. There is no spark from the coil under the seat. The one under the fuel tank has spark. I am hoping once i change the coil it will start. But i am preparing for the worse just in case. Hence my advance questions about the CDI
K3 rear ignition coil cost gerbrox Bikes - Talk & Issues 2 14-02-09 06:26 PM
Ignition unit trouble yorkie_chris SV Talk, Tuning & Tweaking 1 01-09-07 02:16 PM
CDI & coil hovis Stuff Wanted 4 02-07-07 03:54 PM
K3 on ignition coil polishmart Stuff Wanted 0 30-07-06 05:10 PM
ignition coil required. doe Stuff Wanted 0 25-04-06 08:51 PM
