Old 26-04-06, 09:36 PM   #1
mario
Default Am i missing a spacer?
Hi,
Just got new michelin pilot powers fitted onto my 2005 Sv650. Went to fit the rear wheel back on but as i tightened the nut on the spindel the wheel also tightens, eventually locking solid.
I noticed a spacer on the sprocket side but no spacer on the brake calliper side. Question is...am i missing a spacer from the brake caliper side?
Should there be a spacer on both sides of the wheel? Can anyone help please?
Many Thanks
Mark
Old 26-04-06, 09:37 PM   #2
Razor
Without checking facts 100% and never having owned said vehicle I say yes and the fact checkers be damned.
Old 26-04-06, 09:39 PM   #3
Carsick
assuming it's the same as a K4 then yes, there should be a spacer both sides.
Old 26-04-06, 09:39 PM   #4
kciN
There should be a spacer on the caliper side, yes. On the curvey definitely, Can't say for definite on the pointy, but I imagine it's the same.
It looks similar to a cotton reel..
Maybe someone will nicely post up a pic for you??
Did you take wheel off, or garage??
Old 26-04-06, 09:42 PM   #5
kciN
Also, just how far did you tighten the bolt. Did the swingarm get bent in?
Maybe check that it's not bent in to much if this is the case..
Old 26-04-06, 10:06 PM   #6
mario
Right so it must have gone missing somewhere! My dad and I removed the wheel before i gave it a clean and took to garage...however cant see any spacers along my path. Took the bike into a garage to get them to fit the new michelins so maybe thinking it fell out in there?
KciN: Picture would be great if anyone has but reckon i know what it is roughy . Swingarm did not get bent in was only tightened by hand. It looks like part of the brake caliper is rubbing against the brake disk.
The spacer should be between the brake caliper and the wheel if i am correct in thinking?
Got me confused and annoyed now...been off road for a week now and i want to try out my new powers
Old 26-04-06, 10:08 PM   #7
mario
Meant to add:
How much would the spacer cost from a dealer? and would they be likely to have them in stock?
Will also take a look around my garage and garden for the spacer in the light, maybe, just maybe will find it lying about!
Thanks for the help!
Mark
Old 26-04-06, 10:14 PM   #8
Razor
Suzuki dealer would have them in stock if they're any good. I know the spacer for inside a bandit 12 wheel cost about £9, so maybe...
Old 26-04-06, 10:17 PM   #9
mario
Ok hopefully they will have one in then! Shall give my local(ish) dealer a phone tomorrow morning and if in stock shall pop up and collect! Hopefully that shall solve my problem
Thanks again!
Old 26-04-06, 10:17 PM   #10
BILLY
There sould be a spacer on the calliper side it is shaped like a mushroom!!!
Help ,spacer ,where From ? redbiker 954 Mini-Twins 6 16-03-08 04:13 PM
Speedo drive replacement spacer? Sideshow#36 Stuff Wanted 0 20-09-07 10:54 PM
Wheel spacer dilemma.... haggis SV Talk, Tuning & Tweaking 8 08-03-07 11:30 PM
Rubber Mirror Spacer Saucerboy Stuff Wanted 2 26-12-06 05:35 PM
Spacer kit to fit B12 rear wheel northwind SV Talk, Tuning & Tweaking 5 28-03-06 07:03 PM
