Hello people
My bike went through its mot all fine except for a notification thatt he front pads needed changing. The robbing swines wanted close to £120 to change out the pads for me. Was thinking for that price i could replace the pads and install braided hoses on front and rear. now apologies for asking a question that has doubtless been asked countless times before but what pads should i put on and what company and kit should i use for braided hoses? i was confused with 2 or 3 lines, stainless steel etc. Any explanations are gratefully accepted. Its a 2000 curvy. Cheers guys and girls |
The Sick Man
Suzuki OEM pads are good, but you can also use EBC. I was told to stay away from Freodo though, not sure why.
For lines HEL & Goodridge, the 2 or 3 line setup is fine, which ever you want.
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
Thanks
Any idea how difficult it is to fit the hoses? I heard bleeding them was a pain. I think a Haynes manual should be my next investment! Whats the advantage of a 3 line to 2 line? Cheers |
#4 | |
![]() I got charged £500+ for new pads and EBC discs from a local garage ![]() ![]() |
A 3 lines system looks like the originals - a line goes from the master cylinder to the block above the mudguard and two lines go from this to each caliper. A 2 lines system does away with the splitter block and has two lines going from the master cylinder to the caliper. The latter has fewer restrictions in the flow of fluid but you need to route the lines carefully as they don't follow the path of the old lines. On the SV, though, it's very simple.
Don't get confused between a three line package that does two fronts and one rear and a three line package that does just the front, BTW. Check with the supplier what lines are included. This kit has two long front lines and a rear one: http://cgi.ebay.co.uk/Goodridge-Brai...QQcmdZViewItem Bleeding isn't hard but it's made a whole lot easier with a Mityvac. M&P sell them, I think. It's a vacuum bleeder that sucks fluid through the system until it's flushed of air. Don't get a positive pressure bleeding system that runs from the tyre pressure - they're a recipe for disaster as they almost always end up shooting brake fluid into eyes, over paintwork, etc. Cheers Ian[/url] |
Thanks for the links. Ill get the 3 line kit. Im getting slightly concerned at how much money i seem to be spending on the bike! Yet every time i see something else shiny i suddenly realise that the biking experiance will not be complete until i have it. Then its used once and never again....
At least brake pads and hoses are necessary items. ![]() |
The two line kit for the front is easyer to bleed!!!!!!
Purchased a 2 line front and 1 line rear kit from HEL. Mentioned this site and got it for the grand sum of £65 with postage. 25% saving apparently. Bargain. Now just got to work out how to put them on!
#9 | |
Front Brake Hoses and Master Cylinder - Curvy | Big Daft Lad | Stuff Wanted | 1 | 13-02-09 12:37 PM |
Like new stock brake pads SV650 -> 99-07 | Knaapie | For Sale - SV's and SV related items | 3 | 18-09-07 06:27 PM |
Brake pads for SV650 05 plate | aposegil | SV Talk, Tuning & Tweaking | 23 | 14-01-07 02:44 PM |
One side of EBC HH brake pads for a curvy | northwind | For Sale - SV's and SV related items | 2 | 14-01-06 06:40 PM |
Front Brake Pads for SV650 | 21QUEST | For Sale - SV's and SV related items | 0 | 18-12-05 05:46 PM |
