Old 17-05-06, 04:33 PM   #1
mec
Default Cyclone C-11 Alarm System
Hi,
Anybody have any experiences fitting this alarm to a K1 any advice welcome as to location of speaker, siren etc. Also anybody managed to get the remote start to work.
Having some trouble working out how the imobiliser part is supposed to be connected.. not vey clear from diagram and discription that arrived.
Thanks.
Martin.
Old 17-05-06, 05:37 PM   #2
jayjay
I half fitted one of these, i fitted the main bit underneth between the seats and the speaker under the rear seat next to the rear light connection box thingy!
Connected the yellow wires to the rear indicators, connected the red power wire to the + terminal and the 2 black wires to the neg terminal (the black wire with the piece of heat shrink on the end is the antanna)
Locate the main ignition wire on the fuse box (orange one if i remember correctly) cut it and connect the (again i think its the orange wire from the alarm this time, not 100% sure though) to it and rejoin.
I fitted the led light on the rear end just above the rear light.
That was the easy bit, i still have not worked out how to make the auto start work.
You need 2 relays which don't come with the alarm, to connect the auto start correctly
If you are not sure about any thing i would not recommend trying to install it your self, im not even sure the bit i installed is correct
I am going to get the rest fitted by a profesional unless some one on here has a step by step guide.
Old 20-05-06, 12:27 PM   #3
mec
Thanks for the advice I will have a go at fitting the basic alarm the same as you.
Fittimg the imobiliser involves cuttinh the wire that goes to the start switch. Didn't fancy cutting this wire. However as far as I know this does not give you the remote kill facility.
Thanks.
Martin
Datatool System 3 Alarm - Help please Matt Prince SV Talk, Tuning & Tweaking 6 04-12-07 03:12 PM
Cyclone alarm + battery = pain in my bottom Draper SV Talk, Tuning & Tweaking 19 12-10-07 10:32 PM
Cyclone Advanced Alarm KnightRider SV Talk, Tuning & Tweaking 11 21-06-07 11:25 PM
cyclone c11 alarm help BIKER-DENE SV Talk, Tuning & Tweaking 0 11-03-06 12:32 PM
Does any one have the Suzuki alarm system? KayDee Bikes - Talk & Issues 6 06-09-05 08:32 PM
