This isn't really SV650 related, but since I'm now a SV650 owner I figure I can ask general biking questions here....
On the way into work this morning I followed a slight bend in the dual-carriageway at about 70mph on approach to a roundabout. In the bend I started braking gently and downshifting my way through the gears, de-clutching after each change to make the most of the engine-braking. On the change from 3rd to 2nd, the back-end slid out slightly which for a new rider like me was a little scary ![]() (I've read about throttle blipping, but I'm guessing thats a bit OTT for a beginner and there must be a simpler solution) One thing to bear in mind before ripping me to shreds is that the slight bend is pretty long so it seemed overkill to brake and downshift any earlier. Also, the road was damp but it wasn't raining. All tips greatly appreciated...... |
A lot of new SV riders don't use the front brake enough. If you are not comfortable blipping the throttle, use your brakes a bit more and then change down at a lower speed. You'll get the hang of better changing with time.
One thing I would say is don't change gear in the bend. Get the correct gear selected before you enter the bend. Also speed and position should sorted before you enter the bend or you will get that stepping out of the rear wheel (which sometimes looks cool but the consequences of it going wrong are not so cool). If I have to change down in a bend I always blip the throttle to avoid the engine braking and rear wheel spin.
Blipping the throttle is easy if you get the hang of it. I don't do it myself. You might have changed gear down too early for the back to step out. I'm sure someone with heaps more knowledge about motorcycle mechanics and techniques will set you right.
#5 | |
#6 | |
![]() It's nice to hear from you all that I wasn't doing anything completely stupid, and I'll take the advice and work on the blips. So would everyone agree that if the road was straight the best way to slow down would be to downshift one gear at a time declutching after each change? Making a habit of downshifting several gears at a time is bad practice right? |
#7 | |
In the situation you describe that is probably the safest course of action. |
#8 | |
#9 | ||
The Sick Man
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#10 | |
You seem to be saying that you are able to downshift without pulling in the clutch lever, is this correct? |
Dumb computer question | stewie | Idle Banter | 3 | 14-12-08 02:37 PM |
Dumb cleaning question | skyline | Bikes - Talk & Issues | 10 | 28-07-08 02:46 PM |
Track riding question on technique | monkey | Track Days | 16 | 28-10-07 09:00 PM |
Dumb questions from a newbie | smithwessn | SV Talk, Tuning & Tweaking | 7 | 15-08-07 10:46 PM |
Newbie: Advice on Shifting Technique | saden | Bikes - Talk & Issues | 13 | 20-07-06 07:01 PM |
