Old 29-05-06, 09:48 AM   #1
Bevesocth
Default Cleaning standard exhaust, newb question :D
Heyas guys!
I'm sorta new to this forum, and also kinda new to my SV650 (2004 model, black, unfaired), as I've only had it for about a month..
Thing is, up here in Norway where I live (!!!!) there has been some real crappy weather with lots and lots of rain these last few weeks, and of course, my bike got dirty.
Now, case in point, my exhaust has lost that shine, it's got lots and lots of tiny black spots on it. I can scrape them off with my fingernails, but a standard car-shampoo + sponge doesn't clear it off. Should I get some asfalt-remover spray to use on it, or is there some other trick I can try?
also, is it cool to polish the exhaust after I get the black spots off, or will that turn bad with heat and everything?
Old 29-05-06, 09:52 AM   #2
the front pipe discolour's very quickly and i too have problems keeping it looking shiney.
Old 29-05-06, 09:55 AM   #3
wheelnut
Solvol Autosol should be available in Norway.
I never used it myself though :P
Old 29-05-06, 10:18 AM   #4
sparkymarky
I've used Autoglym Metal Polish which does seem to get the crap off - needs a lot of elbow grease though.
Old 29-05-06, 10:28 AM   #5
sv650gerbrit
Default cleaning
The way i clean mine is-using Solvol Autosol tear off a bit of cloth-about 25mm wide and 30-40cm long-put the cleaner on the cloth and wrap the cloth around the downpipe-and just sit next to bike and pull it round-A lot more relaxing and takes about 10mins -it will come up great-
Old 29-05-06, 10:36 AM   #6
i find autosol dont touch it? so i use an abrasive to rub the discolour off.
Old 29-05-06, 10:42 AM   #7
medwaysv
hope this helps
i tend to use varying grades of wet and dry (not sure if you'll know it as this in norway) paper..you know..the stuff that bodyshops use for rubbing down car/bike bodywork,starting with 600 grade gradually working down to the more finer 1200 grade and then use autosol.
unfortunatly to keep it looking nice doing this is an on-going process but a little effort goes a long way :P
Old 29-05-06, 10:44 AM   #8
TC3
The other day i found some marks on my can that would not budge. I had some T cut to hand and put that on it and left it to dry. Used a damp chamois leather and they came off pretty easy but am sure autosol is the way to go
Old 29-05-06, 05:47 PM   #9
Bevesocth
Thanks for helpful replys
Bought a tube of autosol today, and that seems to work wonders still requires a bit of effort, but that's all right pipes are now clean & shiny. Also bought some standard car wax for the black parts, will get to work on that tomorrow or so
Cleaning question ... Pedro68 Bikes - Talk & Issues 12 25-09-07 07:18 PM
Maybe Stupid Question From a Newb. Xamimus Bikes - Talk & Issues 5 24-06-07 09:05 PM
Lixl pipe on '99 SV650 (NewB question) netsurfer SV Talk, Tuning & Tweaking 3 18-11-06 10:49 AM
Cleaning exhaust? FreshAL SV Talk, Tuning & Tweaking 4 17-01-06 05:28 PM
Silly standard exhaust question... Jdubya SV Talk, Tuning & Tweaking 11 04-02-05 04:43 PM
