Old 01-06-06, 06:39 PM   #1
andyaikido
Default Suspension Sag
Sorry if this is posted elsewhere but i couldn't find it.
Got the following figures for sag:
Front: Static sag - 25mm Active sag - 40mm (40mm from fully extended, is that how you are supposed to measure it?)
Rear: Static sag - 8mm Active sag - 30mm (again fron fully extended)
Are these figures about right? I had some static sag figures in an old copy of PB (F-23mm, R-8mm) but it didn't say anything about active sag, I thought active was the more important of the two?
Old 01-06-06, 07:07 PM   #2
NedSVS
Your static sag figures are close enough. I assume by active sag you mean with you sat on the bike in your normal riding position: these figures will only be right if the spring rates are correct for your weight.
Old 01-06-06, 07:28 PM   #3
amarko5
Active Sag being rider sag or in laymans terms with you sat on bike.
I used to get mine set around the 25 to 30mm mark for road use 25 for fast road and 30 for bumpier stretches.
HTH
Suspension M65 SV Talk, Tuning & Tweaking 28 14-12-19 11:47 PM
suspension when 2 up Draper SV Talk, Tuning & Tweaking 5 08-05-08 10:27 AM
What suspension? Mike2165 SV Talk, Tuning & Tweaking 17 26-09-07 01:11 PM
Suspension Cos SV Talk, Tuning & Tweaking 4 17-05-05 12:26 PM
suspension set-ups . . where ? Warren SV Talk, Tuning & Tweaking 9 06-05-05 06:11 PM
