Old 05-06-06, 11:00 AM   #1
TSM
The Sick Man
TSM's Avatar
Default Brake Disk Straightening
I need my EBC Prolites straightened as it seems to show a buzz in the feal when braking at speeds around 50mpg. Nothing major, does not make my bike wobble and when hard braking it does not happen.
Now the problem is that Motoliners will not straighten them as they have not had much sucess in straightening them. So it seems i am stuck, is there anyone else that may be able to do them or should i just live with the problem as its not major?
Old 05-06-06, 11:08 AM   #2
Not to say you're wrong, but the prolites felt slightly vibey to me too under lighter braking- they're rough compared to typical discs, so could it just be that?
Old 05-06-06, 11:10 AM   #3
TSM
The Sick Man
TSM's Avatar
Yep, i could be parranoied but no one else has tested or told me that its ok or not.
Old 05-06-06, 11:19 AM   #4
zx6man
the buzz can happen if you have ebc pads too..mine did it on a zzr (spec with the HH pads). if they are warped you would get a pulsing from the lever, which is VERY noticable
Old 05-06-06, 11:22 AM   #5
TSM
The Sick Man
TSM's Avatar
Yes, i have HH pads. Me being parranoied then. Ile put the disks back on my bike then. I had a nice ride on monday with standard GSXR disks and i did not have to worrey about any buzzing.
Old 05-06-06, 11:25 AM   #6
Viney
TSM, now you are the technical admin of the site, i would expect that you would use the spell checker that you added
Old 05-06-06, 11:26 AM   #7
TSM
The Sick Man
TSM's Avatar
What is there one, ahh yep that little button that says 'Spell Check', totaly forgot that it was there (Not).
men straightening their hair? malks Idle Banter 96 28-08-08 08:12 AM
Straightening of bent rear brake pedal? husky03 SV Talk, Tuning & Tweaking 4 06-05-07 10:23 AM
wheel needs straightening! socommk23 SV Talk, Tuning & Tweaking 16 17-05-06 09:07 AM
Warped brake disk? JediGoat SV Talk, Tuning & Tweaking 10 21-11-05 04:39 PM
