Old 05-06-06, 11:31 AM   #1
triumph5ta
Default click, click from front brakes
1999 unfaired sv650.
Had a constant click click noise when on the move. Traced it to front brake. Stripped out calipers and saw the fornt brake pads wer two different makes... hmmmm. LH ones had three slots in, RH ones had one slot.
Decided to replace pads with new, both sides.
Brakes now free and not binding
Now I dont get the click on the move unless I apply the brakes.
Any ideas why? I cant feel any pulsing through the lever so I dont think its a warped disc... brakes work great apart from clickety click.
Adam.
Old 05-06-06, 11:35 AM   #2
Filipe M.
Could they be 4 clicks per turn?
Old 05-06-06, 12:07 PM   #3
TSM
The Sick Man
TSM's Avatar
It could be the floating disks are a tad loose on the rivets, when you brake the outer rotor moves a tad making it click.
Old 05-06-06, 12:32 PM   #4
triumph5ta
Could well be, it definitely sounds like its more than twice per wheel revolution... Anything I can do about it? Doesnt seem to affect braking performance...
Adam.
Old 05-06-06, 12:42 PM   #5
TSM
The Sick Man
TSM's Avatar
Adam.
Err, then its not like my bike, it clicks once for each time you apply the brakes.
Old 05-06-06, 01:33 PM   #6
fizzwheel
fizzwheel's Avatar
I had a clicking like that with my SV. Turns out my front brake disks were below minimum thickness for MOT. I ended up having new disks and pads.
Old 17-07-06, 11:08 AM   #7
triumph5ta
Still getting this noise, its now happening on the move not just when I am braking but braking makes it louder.
I can wiggle my brake discs easily on their rivets which recreates the clicking noise. I went to look at two used curvy SV650s in a dealers and tried to wiggle the discs on them and I could hardly move them. Seems like I have too much play in my rivets.
I guess I have to replace the discs and the rivets all in one? This is a pity cos the discs them selves are not very worn.
Adam.
Old 17-07-06, 12:13 PM   #8
jambo
jambo's Avatar
You may be able to get the rivets re-done, I know you can buy purely Rivet and braking surface kits for a lot less than full discs, but not sure what you need to fit them, fairly sure it's not just a "tap it wiv a hamma innit" job :P
Old 17-07-06, 12:17 PM   #9
svrash
On the stealth wavey discs, the friction surface was held on by rivets secured with circlips over a washer, give them a call, they do different colour rivets too
Old 17-07-06, 12:18 PM   #10
TSM
The Sick Man
TSM's Avatar
Where? I would love some for my disks.
I think rotational movement is ok, its sideways you dont want much. Not sure though. I know mine have movement but they are ok, but get annoying when riding over bumpy ground as it knocks and rattles.
One click a day!Just like an apple! TOLAROS Idle Banter 10 23-02-09 01:54 PM
Scooter enthusiasts click here......... jumjum_0214 Idle Banter 4 21-04-08 08:53 AM
click keithd Idle Banter 9 10-03-08 01:30 PM
click here pegasus The Essex Lounge 1 02-01-07 08:25 PM
Click Click Click Under Braking TSM SV Talk, Tuning & Tweaking 6 26-08-06 06:23 PM
