Having to take off my breaded hoses and refit them as the previos owner put the wrong ones on, is there a specifict bleeding sequence or just blead one caliper at a time??
I have a K3 naked Thanks ![]() |
One at a time is the way!!!! You may find it takes ages for the fluid to come through!!! I had this prob with mine so I bought a speed bleader kit from HG no effort at all and well worth the £30 I paid for it!!!
Leigh, I would have said that you could take the hoses off at the resevioir end thus minimising the amount of fluid that you would have lost and hence saving a short amout of time bleeding them again. However, knowing what it is that you have to do, your a bit stuffed.
One calliper at a time. Do one, then do the other, then do them again. Rear is the same as it has two bleed nipples. Hmmmm or does it ![]() How's the schock ![]() |
#4 | |
![]() It's so much better mate, bike is alot more solid in the corner and under ower. even started playing with the dampaner settings. cheers again for the lending of you stuff... ![]() |
how exactly do you use a speed bleeder then ?
#6 | |
#7 | |
bleeding brakes - problem | Dave20046 | SV Talk, Tuning & Tweaking | 189 | 20-04-09 07:22 PM |
Bleeding Brakes - Again | HopefullySoon | SV Talk, Tuning & Tweaking | 2 | 28-08-07 09:13 AM |
Bleeding Brakes (Bleeding Kits) | 21QUEST | SV Talk, Tuning & Tweaking | 8 | 20-06-06 05:31 PM |
Bleeding Brakes | sweepdoggydog | SV Talk, Tuning & Tweaking | 9 | 08-06-06 07:07 AM |
Bleeding Brakes | Moo | SV Talk, Tuning & Tweaking | 9 | 21-01-06 07:59 PM |
