Old 13-06-06, 10:00 PM   #1
goof
Default Clutch Drag - calling sid squid ;-)
Well, getting on top of my niggles now but one remains - I've had a sticky clutch for a while now and thought it was my worm drive but after a well overdue cleaning session (big shout out to Jim55 for that ) we discovered the clutch is actually dragging.
I tried firstly adjusting the worm drive end as per the Suzuki manual but didn't have any luck. We then adjusted it to the same settings as Jims but still get major drag. Tried adjusting the grub screw in worm drive back and forth but still couldn't get it to disengage.
So that was us stumped
Is this down to simple adjustment or something in the clutch needing sorted?
Old 13-06-06, 10:05 PM   #2
1) remove clutch lever
2) replace rest of bike
3) fit clutch lever to new bike
Old 13-06-06, 10:11 PM   #3
svrash
Did you clean the rod that the worm drive pushes, IIRC it just comes out and can get clogged up with chain lube holding it out
Old 13-06-06, 10:15 PM   #4
RingDing
RingDing's Avatar
Not at all helpful Northy!
I'm sure someone will be along with some useful tips soon.
http://ridingalongwayslowly.blogspot.co.uk/
3x Honda C110 - phut-phut-phut
KTM Duke 690 - brum-braaaaaaa!!!!!
BSA C25 - brum-braa-braa
RD350LC Ring-ding-phut-clatter-££££££
RingDing is offline   Reply With Quote
Old 13-06-06, 11:09 PM   #5
goof
cheeky goit! My bike pwns you
Rash - didn't remove that rod but it sure is gunked up good.
Old 14-06-06, 03:09 PM   #6
instigator
Do you mean dragging as in when you pull the clutch in fully, it does not disengage the drive (i.e it still wants to move forwards). Mine does this ever so slightly when starting up and warming up, but once fully warmed up and sued, it's fine. I jsut topped it up with some different oil so reckon that's the problem so will give the thing a full oil change.
Old 14-06-06, 04:24 PM   #7
First this:
Originally Posted by Me
Slacken off cable adjusters at top and bottom, loosen lifter locknut, back out screw a bit, ensure that lifter arm is as far down as it will go, gently turn screw in until it contacts pushrod, back it out a bit, (~1/8th of a turn), then nip up the locknut, roughly adjust cable with lower adjuster - not too tight - then with top adjuster ensure that there remains a little slack all the way from lock to lock.
Only when you're absolutely certain that it's adjusted right, and it still doesn't work properly need you look further, and then it's possibly that the lifter is knackered - it only takes a small amount of wear for it to be useless, it's when you see it side by side with a good one that it is truly apparent when it's goosed.
Old 14-06-06, 06:15 PM   #8
goof
Instigator - yeah, it's still pulling quite strongly even when the clutch is in which is why I guess I've been having trouble changing gear.
Sid - thanks for the input. When you say the "lifter" do you mean the worm drive itself? Think I mentioned above, I opened the worm drive and it does have wear outwith the channels.
Old 14-06-06, 06:18 PM   #9
LMAO
haa haaaaa
Old 14-06-06, 08:16 PM   #10
If the lifter has wear - the 'worm' bit you're referring to - it'll never be right, bin it and get a new one, £25-£30~ish or so, as I remember.
You've got a chum with an SV haven't you? Try swapping the lifter first, if that improves the situation you'll be certain of where the problem lies.
Clutch drag, reasons/solutions? nicky-jano SV Talk, Tuning & Tweaking 8 09-03-09 08:49 PM
Calling Sid Squid Stu Soho Massive 2 20-09-08 02:25 PM
calling all geeks(in the nicest name calling way) jim@55 Idle Banter 11 25-06-07 08:55 AM
A total drag! n I don't know why lib-biker SV Talk, Tuning & Tweaking 2 08-06-07 11:15 AM
Took the SV to the drag strip khskenny SV Talk, Tuning & Tweaking 89 12-05-05 08:56 PM
