Old 17-06-06, 03:26 PM   #1
aitch
Default sv k3 dead!!!!!
Question from newbie. Just come back from holiday bike been standing for a week, started her up fine went for a ride about 60 miles, everything seemed ok. Tried to start her at 4:30 this morning and shes absolutley dead. When ignition on no lights, no servo, nothing, totally dead. No alarm fitted completely standard bike. Please please help!!!!
Old 17-06-06, 04:15 PM   #2
lynw
Have you tested your battery to see if theres any charge there?
Sounds like its run down and needs charging.
Old 17-06-06, 04:18 PM   #3
Biker Biggles
Biker Biggles's Avatar
And check your battery connections,and the main fuse.Flick your kill switch a few times too
Old 17-06-06, 04:21 PM   #4
lynw
Ok I read no lights to mean none on the panel. The neutral light should still be on even with the kill switch on IIRC.
So Id say its a battery/fuse thing over the kill switch. But we've all done that one - took me 6 hours once to work it out
Old 17-06-06, 04:22 PM   #5
aitch
Default dead sv!!!
charging battery as we speak all fuses are ok funny thing is when i connect the battery the rev needle go's to 7k for a split second and drops again but then nothing
Old 17-06-06, 04:23 PM   #6
Skullmonk3y
Old 17-06-06, 04:47 PM   #7
Peter Henry
I am sometimes a little slow in reacting when disturbed for a ride at 4.30am myself in all honestly.
Old 17-06-06, 04:52 PM   #8
aitch
Default dead sv!!!
i was on the way to work at 4:30 am this morning
right ALL fuses under seat check out all ok including the 2 green
if anyone has come across this problem before please let me know
also just called colin collins in watford but they cant look at the bike till at least the 26th of this month!! what am i gonna do without her till then?!?!?
Old 17-06-06, 07:15 PM   #9
Flamin_Squirrel
Doesnt the rev counter rising to a certain figure then falling again indicate an error code? I know this is the case on some bikes, dunno about the curvey SV.
Old 19-06-06, 04:35 PM   #10
Filipe M.
When mine did it, the error code went something like "Battery FUBAR: Replace ASAP".
Dead 02 SVS 2whelltraveler SV Talk, Tuning & Tweaking 4 12-05-09 01:25 AM
dead sv hlaf_lyfe Bikes - Talk & Issues 15 26-01-08 09:52 PM
Dead Can? M65 SV Talk, Tuning & Tweaking 19 09-05-06 12:12 PM
HELP - Dead SV Roy650s SV Talk, Tuning & Tweaking 17 01-03-06 08:37 PM
Not quite dead... but definitely ill andyaikido SV Talk, Tuning & Tweaking 0 25-02-06 04:31 PM
