27-06-06, 11:05 AM | #1 |
Volt Meter Fitting
Hi,
I've just got one of these voltmeters. http://www.casporttouring.com/store/...de=Electronics I intend to fit it across the bar risers on my 99 naked. Could anyone suggest the easiest/most convinient place to find a constant 12v supply & an ignition switched 12v supply? I seem to recall reading that there were some "spare" wires inside the headlight on the naked that provided the switched 12v..... is this correct? and what about the perm connection? Thanks Paul. |
27-06-06, 11:15 AM | #2 |
Go here mate. svrash should be able to help
http://forums.sv650.org/viewtopic.ph...644&highlight= Tris |
27-06-06, 01:40 PM | #3 |
IIRC any red is constant live, any black is earth and orange with a green tracer is switched live, i think
27-06-06, 02:11 PM | #4 |
Break into the loom side of the ignition connector block wiring, red is permanent live, orange is switched live.
Stress Meter | plowsie | Bikes - Talk & Issues | 6 | 16-10-07 11:01 PM |
Water Meter | Ceri JC | Idle Banter | 14 | 07-03-07 09:36 AM |
trip meter question | triumph5ta | SV Talk, Tuning & Tweaking | 7 | 21-04-06 09:56 PM |
Speedo & RPM meter keeps dying | SpankyHam | SV Talk, Tuning & Tweaking | 6 | 09-09-05 05:20 PM |
Resetting the ODO meter?? Help!!! | Runner Type R | SV Talk, Tuning & Tweaking | 3 | 20-02-05 10:24 PM |
