Old 28-06-06, 03:40 PM   #1
oldsvrider
Default oil light problem
this has probably been asked loads here but i cant find it in a search
riding my sv this morning the oil light flickers at low rpm and some times stays on for a long time. i have checked the oil but is on the max line. also the gears are getting a little stiff. would this be any thing but a faulty sensor?
Old 28-06-06, 03:57 PM   #2
Check sensor first, substitution is by far the easiest way. How old is the oil filter?
When you say gears getting stiff, do you mean that it's hard to change or that the lever is stiff?
Old 28-06-06, 04:05 PM   #3
oldsvrider
the gears seem heavy, as if the gear box oil is low but i looked in the window and its full
Old 28-06-06, 04:11 PM   #4
You most likely know this but there is no gearbox oil specifically - the engine and gearbox share the same oil. If there's a lack of oil pressure the first area to suffer will most likely be big ends, lots of load and a plain bearing.
I'd be very surprised to find the gearchange to be the area that you would have troubles with first if there was an oil system problem.
Clearly your bike does need to be examined carefully though.
Brake and back light problem. scotty73 Bikes - Talk & Issues 0 09-06-08 07:41 PM
light problem. olden mgroin SV Talk, Tuning & Tweaking 22 26-04-08 05:45 PM
has anyone ever had the FI light and got the code -C23 if so wot was the problem?? sv650k4 Bikes - Talk & Issues 8 28-01-08 12:19 PM
Odd electrical/light problem Ceri JC SV Talk, Tuning & Tweaking 25 30-12-07 07:58 PM
Fuel Light Problem Bez SV Talk, Tuning & Tweaking 8 08-05-06 01:04 PM
