Hello, I'm sticking a ZX10R shock in my bike in place of the soggy Suzuki one and was wondering what mounting bolts I need to fix it in.
Looking at previous posts about this conversion I think I can use either GSXR1000 shock mount bolts or the ones that are for the ZX10R - unfortunately I will not get the bolts with the shock. Does anyone know what bolts I need to get or if I need to get a specific size, what size. Also need to replace a Radiator bolt so if anyone knows what this one is that would be great, Cheers |
Red 5 I did this last week ; I bought a M10x60 bolt which I cut down for the bottom bolt( It has to fit between the Dog Bones) . The upper bolt was one that came with the shock but it was probably M10x55 .
The battery box requires a bit of abuse to make it fit ; cable ties are handy as is some foam/ rubber to isolate the shock reservoir from the battery. It makes a hell of a difference tho'. Hope this helps Joe. |
Thanks it does.....I'm not getting any bolts with the shock unfortunately, so can I use my existing top bolt to fix the shock again?.
I've seen on another SV forum a guy said you can put the top SV mounting bolt at the bottom, then get a gixer thou mounting bolt and put that at the top meaning no need to trim bolts.......not sure if this is true?. Looking forward to it - putting some ohlins springs in the front with 15w oil, I'm 15 stone plus and the ZX10r shock in the rear as my current suspension has gone off. Cheers |
I'm putting mine in this weekend (I have already started but dues to my poor spanner set I'm off to buy a complete set), I wasn't sure if any bolt would do so I got mine from Kwak. I'm gonna try stiking the suzuki on at the bottom like TSM said.
Edit: the top bolt is far too long to use at the bottom but the kwack bolt will fit if you put a washer on the opposite side to the nut. |
Cheers, I've got a gsxr1000 bolt and nut on order which is an M10 55 which other people have said fits without the need to trim on the bottom, I think the kwak one is an M10 60 so 5mm longer.
Wasn't much at all and ordered it from Fowlers in bristol, very easy but then I did know the part number. Let me know how it goes - I'll be doing mine in about 2wks time so if you come across any problems, give me some warning ![]() Cheers - hope it transforms the bike,mine is so bouncy at the moment! |
04/05 ZX10R shock | andyb | Stuff Wanted | 1 | 17-05-08 07:46 PM |
ZX10R shock | neio79 | SV Talk, Tuning & Tweaking | 30 | 12-06-07 08:00 AM |
zx10r shock | weazelz | SV Talk, Tuning & Tweaking | 10 | 26-08-06 08:25 AM |
'06 zx10r shock on '00 S curvy | weazelz | SV Talk, Tuning & Tweaking | 1 | 17-07-06 03:14 PM |
ZX10R K6 Shock | andyaikido | For Sale - SV's and SV related items | 2 | 29-05-06 10:49 PM |
