09-07-06, 07:45 AM | #1 |
what is this called
hi on lifting my tank on my 02 plate sv650 i noticed the air filter box ok manual said it would be there i also noticer the radiator cap said it would be there as well but it doesnt say anything about a black box thing just behind the radiator and is connected by a pipe to the rad just below the filler cap i also noticed the black box thing has a small white window in it but noting showing in window is this normal
09-07-06, 08:15 AM | #2 |
If it has two lines on the white bit, then its called an expansion tank and there should be enough coolant in it to the bottom of the 2 lines.
09-07-06, 08:41 AM | #3 |
Exactly! Should be on the right hand side when looking from the riders seat.
09-07-06, 09:41 PM | #4 |
thats right what have i to do with it whats it for???
09-07-06, 10:14 PM | #5 | |
Coolant 'expansion' tank....says it all really. |
10-07-06, 08:26 AM | #6 |
I have a '99 bike. I can't see the coolant level through the window on mine. It's there though; but the window is now rather opaque.
10-07-06, 12:51 PM | #7 |
As has been explained top the expansion tank up to between the marks. Whilst you are at it, pop the radiator cap off and fill the radiator to the brim. Make a note of how much water it takes to fill. It shouldn’t be much (if any) if it takes a cupful or more, then make sure you don’t have a coolant leak somewhere.
10-07-06, 09:15 PM | #8 | |
What it's called? | 600+ | Idle Banter | 3 | 27-04-08 09:25 AM |
What is it called? | Mike2165 | Idle Banter | 11 | 31-10-07 08:23 AM |
What was the programme called... | Ed | Idle Banter | 6 | 12-10-06 08:37 PM |
I have just been called autocratic | timwilky | Idle Banter | 8 | 21-07-06 11:46 AM |
just called in to say Hi | airbox | South & West Surfers | 9 | 01-07-05 10:44 AM |
