Old 12-07-06, 11:02 AM   #1
Ward8124
Default Bad habit!
Peeps for some reason when i am progressing throught my gears quite hard the damn thing jumps into neutral for some daft reason. The chain is ok and adjusted fine.....sprockets dont look worn so any ideas on what the problem is and how to fix?
Old 12-07-06, 11:22 AM   #2
Warren
id check your clutch adjustment, reset it at the lever end, and adjust from the other end.
also, id check that the lever is engaging the gears properly.
Old 12-07-06, 11:38 AM   #3
Flamin_Squirrel
I'd also make sure you're giving a positive enough push on the lever.
Old 12-07-06, 11:52 AM   #4
Captain Nemo
they all do that Sir!!
nah seriously they do, but make sure that youre giving it a positive enought push when you go up, mine used to be a bit prone to popping out if you didnt give it enough
Old 12-07-06, 11:58 AM   #5
skidmarx
Adjust your gear lever down.
Old 12-07-06, 01:44 PM   #6
wheelnut
get some different boots and try them. Be positive with your shifts, dont be too gentle.
Old 12-07-06, 02:18 PM   #7
Jase22
As above. When you're "making progress" you tend to move in the saddle to have your feet in a different position to when you're commuting / tootling, in that they tend to move further down. Push your lever down a touch and you shouldn't have the problem.
I hit neautral like you, think it's due to a combination of the above and a lazy change action.
Old 12-07-06, 03:01 PM   #8
Ward8124
Cheers for the comments peeps but im not gentle with my shifting and do give a good kick in into gear so it might be the clutch...i will keep an eye on the shifting anyway as i might be getting lazy!
Old 12-07-06, 05:35 PM   #9
RandyO
dirty linkage will have the same effect, make sure it's cleaned & lubed and moving freely
Old 13-07-06, 06:21 PM   #10
Ward8124
Yes the chain was the issue here.....me being lazy and doing my daily commute of 150 miles i havent been greasin her up!!! Bad boy me!
Most annoying car driving habit? MeridiaNx Bikes - Talk & Issues 60 01-06-06 04:20 PM
