Old 22-07-06, 09:27 PM   #1
Blue_SV650S
Default Shock – Horror
Fitted my ZX636 shock (and short dogbones) to my curvy trackbike today. I was a bit concerned with the side to side play in the ‘fork’ bit of the shock where it joins the linkage and how there is literally a piece of papers width of clearance between my nut/thread end and my dogbones!!
It is not wear in the linkage, or slop between the fork and the metal tube bit (I did put a washer in there as the fork width is a mm or so wider than the stock one). Also I cut a bolt so was no longer that was the minimum necessary to fit my nylock on, so it is not like I have a mile of thread sticking out. And it is still a nats away!!! I can see no other way of doing things, but it does seem awfully close and with the sideways ‘slop’ I can see that at a minimum the nut might rub the inside of the dogbone, at worse ‘catch’ if it ever clears the dogbone when the suspension moves?
The stockshock didn’t require a nut as the fork was threaded so there was never a problem … but with the ZX6 shock requiring a nut, have others found it to be a little tight??
Old 22-07-06, 11:14 PM   #2
PeterM
She's a tight fit mate but it works. You may have to take an angle grider to the outside of the offending nut to just make that extra couple of mm clearance for peace of mind.
Old 23-07-06, 08:29 AM   #3
Stig
That's what I did with the Gixxer shock that I fitted. Just ground it down by a mil or two just for reassurance.
Old 23-07-06, 09:07 AM   #4
Blue_SV650S
Does shound like it is tight one .... at least I am not the only one!!
To be fair the thread isn’t really protruding at all … if I took any thing worth talking about off the nut it would be the nylock part … and that would be defeating the object …
I’ll run it, but just keep an eye on rubbing/wear. Does the suspension ever travel enough that the nut could get trapped under the dogbone (and hence catch and edge)??? Or is my worst case here just a bit of rubbing?
Old 24-07-06, 10:41 AM   #5
sdusk
Can you turn it around so that the bolt head is where the nut is now, and then grind it down a bit instead?
Old 24-07-06, 10:48 AM   #6
Blue_SV650S
Say what now??
If I was to put the bolt in the other way round, then I get the same problem, but the other side … the head of a bolt is thinner than the nut, especially as I need to be using a retaining nut (nylock).
Old 24-07-06, 11:00 AM   #7
TSM
The Sick Man
TSM's Avatar
Say what now??
The shock is not dead center between the dog bones, there is more space on one side than the other. I did not have to cut any bolt when i fitted mine.
Old 24-07-06, 11:09 AM   #8
timwilky
timwilky's Avatar
Also do you need to use a nyloc nut. Would an ordinary nut with Loctite thread lock not be as good with a lot less space used.
Not Grumpy, opinionated.
Old 24-07-06, 11:26 AM   #9
Black Rider
I didn't know Sean Connery was on this forum!!!!
Sounds like a good idea - Zx636 shock on the SV ... mmm ...
... my mates got a zx636
Old 24-07-06, 11:32 AM   #10
Jase22
I used a couple of washers to space out the dog bone on the side where the nut is. Did the trick for me.
Clarkson admits being wrong! Shock Horror! AlanSv Idle Banter 17 08-01-08 02:04 PM
SHOCK, HORROR!!! Lissa Bikes - Talk & Issues 26 06-07-06 11:48 PM
Shock, Horror ;) mudge32 Pennine Massive 11 03-05-06 08:15 PM
Shock Horror! Jambo cleans Kwak! jambo Photos 14 07-03-06 09:39 PM
Shock Horror! Jambo cleans Kwak! James Idle Banter 2 06-01-70 05:47 PM
