Old 24-07-06, 08:10 PM   #1
creamerybutter
Default Brake dust seal has come out....Bugger
Ok I was changing my brake discs and while the callipers were off I decided to give the pistons a little clean, I pushed the brake to push the pistons out (with the pads still in as I did last time) and one of the dust seals came out with the piston. Anyway I need to dismantle the calliper and replace them (and clean everything while I am at it) and I am fairly confident after reading the manual from the site that I know what to do but I was wondering if there is anything else I should watch out for that the manual doesn't warn you about.
Any advice wold be much apreciated.
Old 24-07-06, 09:49 PM   #2
when i did my zzr i was just told that the most important thing was to keep everything really clean.
Old 25-07-06, 12:10 AM   #3
Under no circumstances use brake fluid as a lubricant to ease fitting of the seals, buy some proper rubber grease and use it.
Old 25-07-06, 07:32 AM   #4
lukemillar
Did this recently - As Sid say uses red rubber grease on the seals. The stuff is actually quite hard to find - I had to order it online from some MG owners site as Halfords and some locally run car places didin't have any.
Old 25-07-06, 07:36 AM   #5
Viney
Could you use Any rubber lubricant?
Old 25-07-06, 07:47 AM   #6
petevtwin650
I was told that the dust seals aren't very important, especially if you clean the brakes regularly as you need to on Sv's. Why is it a big No No to use brake fluid to lube the seals though?
Old 25-07-06, 08:27 AM   #7
creamerybutter
Cheers guys.
I figure they are there for a reason and as my brakes haven't really been cleaned that many times in 15500 miles and they are still the original seals they could probably do with a change anyway. The callipers need a good clean anyway.
Also anyone know where to get a peice of hose from (silly question I know but I have no idea).
Old 25-07-06, 08:31 AM   #8
Viney
Originally Posted by creamerybutter
I figure they are there for a reason and as my breaks haven't really been cleaned that many times in 15500 miles and they are still the original seals they could probably do with a change anyway. The callipers need a good clean anyway.
its BRAKES
That is all
Old 25-07-06, 08:32 AM   #9
creamerybutter
Thats what I said...
Old 25-07-06, 10:30 AM   #10
creamerybutter
Why? I was reading the manual again and it says that you should put brake fluid on the seals
Front Caliper Dust Seal mikebrooman SV Talk, Tuning & Tweaking 5 25-02-09 12:50 PM
Brake caliper dust seals rockster SV Talk, Tuning & Tweaking 7 26-01-09 10:29 PM
Brake seal suppliers chazzyb SV Talk, Tuning & Tweaking 7 09-03-07 10:44 AM
brake dust seals only 2.50 each at Hamilton Motorcycles! Dirty Baz SV Ecosse 2 10-01-06 10:41 PM
Brake Dust Seals leegriffiths128 SV Talk, Tuning & Tweaking 2 16-12-05 06:59 PM
