Old 25-07-06, 10:18 PM   #1
21QUEST
21QUEST's Avatar
Default What solder to purchase
Question for the soldering gods. (Shouts out to Viney,Sid,Rictus,Embee,TimW,Ape ...)
I hate electrical stuff and have always had someone good to do any tricky bits. Failing that I just bodge way out Subsequently never had to do much soldering . I need to do some rewiring(bike) and my electrical maestro hasn't got the time so now is as good a time as any to see what all the fuss is about :P
Quick look at maplin provided two different types of solders one of which is almost twice the price of the other. Question is is it worth bothering with the expensive one or will the cheaper one suffice. Link below
http://www.maplin.co.uk/Search.aspx?...25m7&source=15
Any suggestions , tips welcome
Ben
Nemo me impune lacessit.
Old 25-07-06, 10:25 PM   #2
andyauger
None of those are necessary. Silver solder requires higher temperatures to work. Lead free solders are generally used in plumbing. Standard electronic resin-core solder is what you want. Electronics shops and hobby shops will have the correct stuff.
Old 25-07-06, 10:38 PM   #3
21QUEST
21QUEST's Avatar
Thanks Andy.
Will any of the above be okay though? Maplins is the only place I can think of at the moment which is handy for me on my travels.
Ben
Old 25-07-06, 10:46 PM   #4
independentphoto
No problem with any of those. A 250gm reel of the 1mm lead-free stuff should last you a long time. "Rosin" cored solder (almost all these days) cleans the metals to help the solder take to the joint easily.
Quick tips (in this order):
1) wipe the tip of the HOT iron on a damp sponge to remove oxidised solder
2) "Tin" the tip with a small blob of solder (Aids heat transfer)
3) Offer the tip to the terminal / wire and watch for the solder "wicking" along / into metal.
4) offer the solder wire to the joint until it flows in a modest covering
5) Remove solder wire THEN.........
6) Remove soldering iron.
Do all of the above in a couple of seconds (unless heat transfer is slow). If the wires insulation starts melting, you've been in there too long. Oh yes.... and feel free to practice with some off-cuts of wire on a bench before starting.
Hope this helps.
Garry
Hope this helps.
Old 25-07-06, 10:52 PM   #5
21QUEST
21QUEST's Avatar
Originally Posted by independentphoto
Good Stuff...
Garry
Hope this helps.
Oooo....h , so that's what all the fuss is about .
Ben
Old 25-07-06, 11:12 PM   #6
tigersaw
tigersaw's Avatar
60/40 multicore is the easiest to use. Being phased out, health and safety, but get it if you see it.
Old 25-07-06, 11:16 PM   #7
Why bother, use molten flesh like I always end up doing
Old 25-07-06, 11:33 PM   #8
21QUEST
21QUEST's Avatar
Tiger , why is it easier to use and what's the H+S deal with it ?.
Ben
Old 25-07-06, 11:40 PM   #9
tigersaw
tigersaw's Avatar
Ben
60% lead, 40% tin, with flux in the core.
melts at low temp, flows easily, does not erode the soldering iron tip, (much).
Think its the fumes that getting it phased out. Fortunately we have about 50 years worth stashed.
Old 25-07-06, 11:50 PM   #10
Graham
Resin core solder is crap, Just use solid solder with bakers flux
Help me with this possible purchase? RayRay SV Talk, Tuning & Tweaking 9 31-12-08 07:37 PM
New purchase. ocr_sv SV Talk, Tuning & Tweaking 10 02-05-08 04:10 PM
Help with car purchase? svJvJ Idle Banter 22 28-08-07 09:14 PM
IT Help - Purchase of new PC hovis Idle Banter 14 05-09-06 10:29 AM
Pak-a-mak purchase Moriarty Helmets 8 17-08-05 11:47 AM
