Old 26-07-06, 09:51 PM   #1
krl
Default Clutch Noise
My 01' with 12K miles has started to sound like a dry clutch Ducati on de-acceleration. Any idea if my clutch has had it? Still works well...
Old 27-07-06, 08:12 AM   #2
Adjust it first, as usual, if no improvement then a look under the cover may be warranted.
12,000 isn't much for the standard clutch, you can expect much more than that, so whilst possible the clutch is worn I'd look elsewhere first.
Old 27-07-06, 12:59 PM   #3
andyauger
Default Are you sure?
The clutch is generally dead silent unless you are running way to low on oil. I would check the chain tension and the condition of the chain slider on top of the swingarm. Then I would measure the links per the owner's manual to see if the chain has too much stretch for service.
Old 28-07-06, 01:45 AM   #4
krl
Default clutch noise II
I said de-acceleration what I mean to say is, during the return to idle from a brisk free rev. Clutch in or out no matter. Momentary clatter (Ducati like) on the way down. Speaking of which. Have you seen the new Cycle World? V-Storm v. Ducati Multistrada 620. Interesting?
Old 28-07-06, 02:31 AM   #5
Graham
The clutch basket has a cushion drive built in with 4 springs. These springs collapse a bit over time and could definitely be the noise your hearing.
Wurring Clutch Noise - Help needed andywilson460 SV Talk, Tuning & Tweaking 8 25-08-08 11:20 AM
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
Screeching noise? what noise does your SV make? branny SV Talk, Tuning & Tweaking 5 30-06-06 12:09 PM
Clutch noise? video within merlot SV Talk, Tuning & Tweaking 8 16-04-05 12:56 PM
Clear clutch covers to see the clutch spin while running. TLRMAN SV Talk, Tuning & Tweaking 13 01-11-04 02:18 PM
