Old 02-08-06, 12:12 PM   #1
aliBONG01
Default Advise please
Right you techno-types, what is the best replacement for the rear shock on an 2000 model sv-s?
I have progressive fork springs up front with slightly heaver oil and JHS dog bones at the rear.
Oh yes, and i weigh 12 stone if that's any use?
Also i have just bought motrax LED indicators and the relay to go with, but i cant get the bloody things to work!!
I have a full wiring diagram but no instructions of how to do it. Do i bypass the original relay or use them both together? PLEASE HELP!
Old 02-08-06, 12:18 PM   #2
BillyC
BillyC's Avatar
If you only weigh 12 stone... then the best thing is probably a stock SV shock.
You don't say how many miles yours has done... if it's high, it's probably knackered.
Old 02-08-06, 12:55 PM   #3
jambo
jambo's Avatar
Do a search on shocks it's been covered really quite a lot.
Old 02-08-06, 01:13 PM   #4
MattTheLoony
There is best and there is cheapest. Really depends on how much you want to spend
Old 02-08-06, 01:27 PM   #5
aliBONG01
Nowt too expensive, just want a bit more positive handling and to get rid of the last bit of chicken strip!
Old 02-08-06, 01:34 PM   #6
lukemillar
Have you tried sandpaper?
#24 - Honda VFR400R NC30
lukemillar is offline   Reply With Quote
Old 02-08-06, 01:34 PM   #7
MattTheLoony
Most people stick in a SRAD GSXR1000 shock, you can usually pick them up on ebay quite cheap. Other options are a ZX10R or a 636 shock. For all of these you will need to trim the battery box to fit the piggyback reservoir.
I'm in the process of fitting a K4 GSXR1000 shock to mine and it's going well so far but not sure what the final result will be yet.
Old 02-08-06, 02:14 PM   #8
aliBONG01
Thanks, i will have a skegg for one.
Old 02-08-06, 02:16 PM   #9
jambo
jambo's Avatar
The SRAD was a model of GSXR 600 & 750 from '97 - 2000 (I could be out by a bit on that) There was no GSXR 1000 at this point.
Old 02-08-06, 06:41 PM   #10
MattTheLoony
My mistake, I thought there was.
Advise please wilky007 SV Talk, Tuning & Tweaking 6 12-11-08 08:15 PM
not sure how to word this...advise please Dappa D SV Talk, Tuning & Tweaking 5 21-07-08 01:01 PM
advise for a new guy? jay boi Idle Banter 23 10-04-07 03:57 PM
Business Advise Please DoubleD Idle Banter 12 13-09-06 08:04 PM
wax on , wax off - please advise. Warren SV Talk, Tuning & Tweaking 13 16-03-05 08:57 PM
