Im having what i think..are serious issue with my sv's front brake..
Basically its CRAP! Bled it twice and it has goodridge braided hoses on, but theres hardly any feel to it!, its a case of it stops(the bike) when the lever is near enough fully back against the bar ![]() Its not just me, my other half took it out and agrees. HELP!! |
Sounds like to me you have air in the system still.
Try bleeding it again, also I found tapping the caliper lightly released some of the air that was in there. Also theres a tip that I was given about zip tieing the brake lever to the bars over night as the forces any small air bubbles up out through the system. Failing that it could be your calipers are full of crud. Might be time for a strip down and a clean.
Sounds like you've still got some air in the system try cable tying the leaver back to the grip over night and see if that improves it!!!!
Hi I raised the same point some weeks ago and the concensus was - well the cheapest upgrade was the pads themselves. Then the master cylinder, then the suspension, then replace the whole fron end, in terms of improvement by cost. I have yet to order the pads, but intend to.
I realy noticed the "poor" brakes when I had an R6 for a day. Of course everything is relative. But I'm going to get some pads. Carbon Lorrane's I think was the choice. I have no idea where you can buy these, probably Demon Tweaks or similar. |
Did you bleed the master cylinder?
If still having problems after been bled correcting , check your seals. Cheers Ben |
I have exactly the same problem. With mine it's the pistons and seals in the caliper that's shot.
Worlds end motorbike parts do replacements but they're not particularly cheap (£80 for pistons and £40ish for seals). It's really unnerving when you can pull the lever back to the bars before it starts to brake. I've been trying the cable tie trick for the past month or so and it makes little difference when the seals are getting old. Aparently, the seals grip the pistons and pull them back into the calipers when you release the lever. |
Mine was crap... fluid bleed, pads changed, seals replaced... still not there... Got a master Cylinder service kit and now its lovely again.
If the lever's coming back to the bar it's not Pads. It's air or seals.
Pads will alter the bite and effectivness of the stopping but not the feel from the lever. Jambo
#9 |
Cheers guys, will try the cable tie trick tonight and see how she feels, thats doesnt work i'll get my other half to look at the seals etc.
#10 |
When I fitted a set of braided hoses and bled the system I demounted the whole master cylinder from the bar and waggled it about so that any air trapped in the top of the master cylinder came to the top and up the pipe into the reservoir.Sure enough a few bubbles emerged,so you could still have air in there.
Curvy Front Brake Lever | JamoSV650s | Stuff Wanted | 1 | 21-02-09 10:52 PM |
99-02 MODEL Curvy L/H-R/H Front Upper Panels Black | GAZER | Stuff Wanted | 2 | 23-10-07 08:55 PM |
Front end- 2000 curvy model | SDMF | Stuff Wanted | 2 | 22-09-06 01:05 PM |
Curvy rear brake caliper (working) 99 model | alex.j | Stuff Wanted | 9 | 22-07-06 05:48 PM |
FRONT BRAKE SWITCH, 99 CURVY | Well Oiled | Stuff Wanted | 1 | 07-06-06 01:10 PM |
