Old 05-09-06, 05:30 PM   #1
jim@55
Default changing spark plugs
my bike developed the surging /one plug firing after a recent wet outing ,,so i was going to change the plugs anyway and thought this'll b an ideal time ,,,so you know the drill ,,couldnt get the tool in prop(oerr)so off comes the fairing ,,nope still no joy ,so loosened the rad off and moved it back a bit nope not enough room ,,so disconnected the hoses (in the process emptying the contents all over the place) and moved it right out the way ahhh thats btr more room now ...the f!"£"$ing spark plug key didnt fit!it was the wrong one!!barsteward !!so put all the bits back and never even changed the plugs ,and had to refill the rad ...so now i dont know if theres enough coolant in the bike AND the same spark plugs that i started with,,aarrgghh
Old 05-09-06, 05:34 PM   #2
Jabba
Much easier with a naked IL4
Old 05-09-06, 05:39 PM   #3
valleyboy
The one with the toolkit in the bike will fit...
Old 05-09-06, 06:27 PM   #4
jim@55
vb ,,it was the one in the toolkit i tried but it deffo doesnt fit (i tried it on the new ones and its too small)maybe somebody put the wrong one in the kit ,it'll fit something else but not an sv ,oh well
Old 05-09-06, 06:32 PM   #5
Jools'SV Now
or you've got the wrong size plugs fitted - hence your problem
Old 05-09-06, 06:55 PM   #6
It's fairly easy with the right tool Assuming the new ones are CR8 or 9E?
Old 05-09-06, 07:01 PM   #7
TSM
The Sick Man
TSM's Avatar
There are two bits in the tool kit that look like they take the spark plug off, its the larger one with a opening gap of at least 1.4cm and it will be a hinged tool.
Old 05-09-06, 09:12 PM   #8
jim@55
i havent got that then ive got what looks like a long socket with the wrong size ends for my plugs and yes northy theyr the right ones i might b looking to buy one as im goosed ,the bike is ok and running but if i ever really need to change them im in trouble
Old 05-09-06, 09:22 PM   #9
You should be able to blag one off someone else easy enough... Thing is, most of the plug tools you can buy in the shops need loads of effort to get to the front spark- the Suzuki one, you can do just by shifting the radiator a little. Worth having... In fact, it and the c-spanner are the only bits in the kit that aren't just crap IMO.
Old 05-09-06, 09:33 PM   #10
jim@55
so,,,,get the suzuki spark plug tool ,,,,,is that what ure saying ???if so any idea how much roughly this and can u just buy that itself ??all i really need is that and the c spanner
spark plugs daddy_sperm SV Talk, Tuning & Tweaking 12 01-03-06 06:12 AM
Spark Plugs fred_dillon SV Talk, Tuning & Tweaking 5 19-06-05 06:45 PM
Spark Plugs valleyboy SV Talk, Tuning & Tweaking 15 18-05-05 07:51 AM
spark plugs weegaz22 SV Talk, Tuning & Tweaking 4 04-08-03 05:04 PM
changing spark plugs Saracen Idle Banter 9 08-01-70 11:27 AM
