How many questions have I asked/threads started about this exhaust?
Anyways: There's this see thru' plastic covering the carbon fibre bits of the exhaust. Do I remove this? I'm thinking, "plastic melts" The instructions state, " Peel back the protective film on the silencer (WHERE APPLICABLE)". Is this me? My next question is probably going to be, "Which way up do I hold the hacksaw?" & "Do I cut from left ot right?" or something. Shouldn't be allowed near a bike ;o) Ta muchly. |
um, btw: Going to ring the insurers then stick it on tonight if they're okay with this (with baffles for the time being).
The see through stuff, yes.
I've never had it on new CF exhausts though. Re: the hacksaw. No idea what is best but you'll be tired at the end of it. If you're neighbour or neighbours neighbour has a angle grinder and safety hat and gloves, pay them a fiver to borrow it and save your self the hassle. Not what you wanted to hear I know!! ![]() ![]() |
Just a couple of words of caution.
carbon fibre cans suffer if they aren't repacked regularly, the hot exhaust gases will bubble the carbon and it's f**ked, so make sure you repack every 4.5-5k. Also if you do use an angle grinder make sure you have a cutting disk and not a grinding one, with a 4" or 4.5" you wont get all the way so just use the haxsaw on the last bit. Cheers Mark.
#5 | |
Dirk |
#6 | ||
Personally, in my experience mate, don't worry about it. 4-5k is scaremongering, mine have lasted a lot longer. ![]() |
Inside the Can itself between the tube that goes through the middle which is full of holes, and the outer carbon fibre sleeve that you can see is the "packing" which is effectivly a high-temperatre cotton wool type stuff, this absorbs a lot of the noise, and also provides a layer to protect the sleeve from the heat and pulses from the exhaust.
Carbon fibre is less able to deal with this than alloy / stainless steel, so as it (The padding) gets blown out of the back of the bike over time it starts risking being dammaged. Edit: Pretty much what he said... Damn my slow typing ![]()
Inside a carbon fibre can there is normally wadding which is designed to dissipate the heat and sound coming out of the exhaust:-
![]() This gradually burns away, which makes your can sound louder and louder. With less packing, the can might feel hotter, and eventually might split. It MIGHT last a lot longer than 5k however it is not worth taking a chance. You can get the wadding from lots of aftermarket places (I think demontweeks do it) for about £10. It is simply a case of dismantling the can, replacing the wadding and re-rivetting it back together. HTH
2000 - 2004 SV650S 2004 - 2009 SV1000S 2009 - 2013 Triumph Sprint ST1050 2013 - 2016 Triumph Explorer 1200 2016 - Ducati Multistrada DVT S ![]() |
#9 |
unless it came with a lifetime warranty like my scorp.
#10 |
and my blue flame!
Leo Vince carbon fibre Slip-on Exhaust | Pam | SV Talk, Tuning & Tweaking | 3 | 20-03-09 10:19 PM |
Carbon Fibre Bar Ends New!! | Sally | For Sale - SV's and SV related items | 1 | 12-02-09 07:11 AM |
Scorpion Round Carbon Fibre Exhaust | 650sx | For Sale - SV's and SV related items | 2 | 05-07-07 07:51 PM |
can i drill carbon fibre? | adamfool | Idle Banter | 15 | 04-05-06 10:47 PM |
Carbon Fibre. | Peter Henry | Bikes - Talk & Issues | 21 | 03-05-05 11:25 AM |
