Old 11-09-06, 08:28 PM   #1
Warren
Default lets talk wheel bearings.
as the title says,
when i spin my rear wheel by hand, i can hear a clicking noise coming from the rear sprocket area, i dont think its the chain, as there is nothing to click really, checked the brake disc, and took the calipar off. and still hear the clicking noise.
i can feel a very slight vibration through the wheel when i roate it by hand,
i can hear the clicking noise when the bike is coasting.
i take it this means my bearings need replacing,
there is no side play in the wheel.
and the bike handles as normal.
questions . . . .
is it safe to ride ? or is it a case of only ride if i need to.
anyone had a wheel bearing fail on them before while in motion ? what tends to happen ?
i know it can lead to a snapped chain - which is something i want to avoid.
i take it one of the little bearings has cracked, or chipped, causing resistance as the turn round ?
Old 11-09-06, 08:49 PM   #2
are you sure its not the chain going on to the sprocket teeth? cuz mine does that.
is your wheel line'd up right? if not your chain could be going onto the sprocket wonky.
Old 11-09-06, 09:06 PM   #3
Warren
ill have another check later, but the clicking isnt in synch with the chain going over the sprocket.
Old 11-09-06, 09:14 PM   #4
svrash
Chains don't wear evenly
Lube it first, it might stop the clicking
Old 11-09-06, 09:21 PM   #5
TSM
The Sick Man
TSM's Avatar
You can also get clicking from the gearbox (even in N).
Old 11-09-06, 09:37 PM   #6
fizzwheel
fizzwheel's Avatar
Valleyboy to the thread please...
Old 11-09-06, 09:38 PM   #7
instigator
If no side play, I would look at the other solutions mentioned above. I take it you had the rear wheel off the ground at the time though? That is the proper way to check.
I could tell the front wheel bearings were going on my diversion. It would click/kadunk every rotation but only now and then and it wasn't that loud. Until one day (in largs) the sound increased and increased until an almighty CRUNCH came from the front wheel. Was fine afterwards.
1 month later and I do the front wheel bearings - Both were totally gubbed, bits of bearings just fell out. I was lucky.
Old 11-09-06, 09:42 PM   #8
Warren
i had just lubed the chain after i started hearing it. . . thats how i noticed.
then i been keeping an eye on it, and its still doing it,
im pretty sure its not the chain.
i take it bearings are a bugger to do yourself, i used to do em on my skateboard and skates, but motorcyles are quite a bit bigger.
Old 11-09-06, 10:17 PM   #9
Troubleshooting... Take the chain off and spin the wheel. If it doesn't go away, take off the rear caliper. If it still doesn't go away, it's a bearing. Or a crocodile with a clock in its stomach
Old 12-09-06, 05:05 PM   #10
xrphil
you should be able to tell if its a bearing, with the rear wheel off the ground grab the wheel at 6 o`clock and 12 o`clock ( position not time ) and try to move it pushing top and pulling bottom then vica versa it should have little or no movement, try same at 3 and 9 o`clock positions.
if there is movement they could be on the way out, be careful the movement is on the spindle, I changed bearing becuase MOT said to, only to find it was a suspension bush!
changing them is quite ok if you are reasonable at home maintanence, usual hard bit is getting the old bearing out. I use old bearing then a socket to drift new one home.
lets talk insurance..(renewal price difference) kwak zzr Bikes - Talk & Issues 39 24-03-07 11:22 AM
lets talk RF ariels and antennia Warren Idle Banter 20 21-08-06 08:03 PM
Lets talk about throttle bodies (phoarrr!) thor SV Talk, Tuning & Tweaking 13 06-02-06 10:27 AM
Lets talk about bike comms stewboy SV Talk, Tuning & Tweaking 16 27-01-06 07:27 AM
lets talk service Warren Bikes - Talk & Issues 9 16-05-05 04:06 PM
