What's the pros & cons of the above conversion?
How easy is it? |
Pros: Seems to be fairly easy. You can fit a 170 or 180 tyre safely, it'll take an SV disc, and it's lighter than stock. Looks exactly like standard too, though beefier.
Cons: I can't summon up the energy to finish it, so the wheel's in teh garage with a tyre half on it and no spacers. Though I think that's more of a Northwind con than a B12 wheel con. Also... The SV has precisely no need at all for a fatter tyre, you'd probably get a handling benefit from going down to a 150 instead of going up. Tyres are more expensive but won't last any longer. You can't just pick up chain and sprockets so easily, B12 is 530 and SV is 525 so you either need a custom B12 sprocket or you need to go up to the heavier 530 chain. Some will tell you it'll ruin the bike's handling and make it turn in too slow. I bet you a pound they've not ridden an SV with a 180 tyre ![]() Ask Billy and 21Quest, they've actually fitted the things instead of just buying them then putting them on a shelf. Well, Ben did a GSXR1100 one but it's the same deal.
I've got to shoot now so can't type much(no change then
![]() Since you appear not to be busy today Northy(or is that same as usual I guess ![]() ![]() ![]() I'll be doing again but maybe a little bit diiferent. I'll PM you later with regards to it. Now pull your fingers out eh :P Cheers Ben |
Bandit rear wheel | Kulay | SV Talk, Tuning & Tweaking | 0 | 31-08-08 02:48 PM |
Bandit rear wheel - too tight? | Kulay | SV Talk, Tuning & Tweaking | 14 | 16-07-08 01:50 PM |
Bandit 1200 rear wheel for sv650 | Kulay | SV Talk, Tuning & Tweaking | 13 | 14-01-08 08:45 PM |
Bandit 12 rear wheel | BILLY | SV Talk, Tuning & Tweaking | 14 | 12-06-06 09:09 PM |
Bandit 1200 rear wheel | BILLY | SV Talk, Tuning & Tweaking | 19 | 26-03-06 12:51 AM |
