Old 26-09-06, 03:48 PM   #1
hovis
Default camera help
just got a didgital camera off ebay, put brand new AA batterys in & it cutting out after about 5 secs. do i need specail batterys??? got to go late for work again back at 11 any help
thanx
Old 26-09-06, 03:51 PM   #2
Baph
does the camera definately take AA's? Manufacturer & model?
I'd suspect it either NEEDS the highpower ones, or the batteries you put in it aren't 100%.
Old 26-09-06, 03:59 PM   #3
cheapo diji cameras seem to eat batteries so if its a cheapo one try good batt's
Old 26-09-06, 04:16 PM   #4
Beenz
You should go for rechargable batteries, they last a lot longer than normal AAs in digital cameras. Oh and you will need a lot of em. Older cheaper cameras were very power hungry.
Old 26-09-06, 04:18 PM   #5
Nekkid
Are they rechargeable batteries? If so, you need to charge them before use.
What exactly do you mean by cutting out?
First thing to do is try new batteries.
Old 26-09-06, 06:39 PM   #6
Jdubya
You sure that you didnt buy a dodgy camera?
Old 26-09-06, 07:09 PM   #7
Alpinestarhero
Try and get lithium batteries - these have alot more energy avaliable than Nickel-cadium ones.
Matt
Old 26-09-06, 08:01 PM   #8
embee
embee's Avatar
Deffo need rechargeables just to deliver the grunt the early digicams needed. Even brand new alkalines would often only do half a dozen shots before running out of puff.
NiMH probably the best compromise for what you need, perhaps try
http://www.eurobatteries.com/sitepages/nimh.asp
bigger capacity the better, 2500mAh about the biggest AA available, don't bother with 1300mAh or similar which is what some AA rechargeables are.......
and of course you'll need a charger.
That's just one of the big advances in digicams, battery life.
Old 26-09-06, 08:34 PM   #9
zunkus
embee is right.
Mostly you should check the Ah the camera requires.
Higher Ah batteries are better. If the Ah of your battery is lower than required the camera won't function properly after a few shoots.
Old 26-09-06, 08:44 PM   #10
My old camera used to eat AAs like that... It'd last forever on the CRV3s, several hundred shots with LCD and flash, but I only got about 30 out of brand new Duracell AAs. They were still fine for other stuff, though.
Does the camera have the option of a purpose-made camera battery? CRV3 is the same size and shape as 2 AAs, you used to find quite a lot of cameras that took either.
Bike camera or camera mount! chompy Stuff Wanted 3 16-03-09 04:16 PM
So i want a new camera... Viney Idle Banter 29 09-12-08 10:18 PM
New camera van FeRoL Soho Massive 1 21-07-08 09:59 PM
New Camera... DavieSV The Madlanders 7 13-02-08 04:14 PM
camera hovis Idle Banter 51 23-09-06 10:23 PM
